While I was out of the office today E10 started running very slow. We have been live since March and have had Nathan at Epicor support fine tune the installation settings several months back. A call to support resulted in them sending a patch that fixed a memory leak but that doesn’t seem to be the problem because right after restarting the CPU goes over 90% and stays there.
Running both E10 and SQL on separate virtual vmware servers. I can bump the processors up but since we have been running well for 9 months I assume it will just use up whatever processor I throw at it.
Have you ever used a product like Process Explorer - Sysinternals | Microsoft Learn or Process Hacker before? You can get more details on what exactly has that CPU usage ramped up. You might also want to try and kill Task Agent and see if it settles down. I’ve also seen it where bad data/bug in Epicor will ramp up the CPU by way of SQL queries.
that process showed that our production server is causing the huge load (90757835 rows returned). I was working on enterprise search management a couple days ago. Now the Search Server doesn’t show in the Admin Console. Possibly related?
Whew…back to full speed. The process that I had left running to fix the customer TotOpenOrders error was hung up on my computer. I would have thought that would have cleared when the server was restarted.
I have always found most user run conversions in the workbench can cause problems. It’s best to run these after hours just in case something goes wrong.
I have one conversion where the status has been stuck on “started” for months, doesn’t seem to be causing issues, but still, I think these conversions are mostly half-baked.
