Our test environment has been updated to Kinetic 2023.1 from 2022.2.11. All customizations using dynamic query adapter are failing to compile. These customizations were working perfectly fine in 2022.11, assembly references are present. Dynamicquery dll exists (in correct location) and is not disabled. Error message reads…
The type ‘Ice.Lib.Bpm.IDynamicQueryAdapter’ is defined in an assembly that is not referenced. You must add a reference to assembly ‘Ice.Lib.Bpm.Shared, Version=4.2.300.0, Culture=neutral, PublicKeyToken=37a5ccb872c00aec’.
Because of BPM designer for browser - common interfaces were shared between client and server and moved into shared assemblies. Looks like some of customization code requires this assembly to be added explicitly
Hello Olga, I’m having the same issue. I added this line “using Ice.Lib.Bpm.Shared;” but it results on: The type or namespace name ‘Bpm’ does not exist in the namespace ‘Ice.Lib’ (are you missing an assembly reference?)
What I’m doing wrong?
Sorry, I’m not familiar with code customizations; how do I add them? I went to Tools - Assembly Reference Manager and it seems to be able to add nothing but custom references
