I have a Dynamic Query which populates in a grid based upon a partial search of the PO Num.
When the proper PO Num Row gets highlighted I want a text box to fill with a column entry from the grid.
I have created an After Row Activate Event on the Grid. I am unsure of the proper code to get the text box to equal a column from the grid.
//Order - PONum Leave
private void txtOrderHed_PONum_Leave(object sender, System.EventArgs args)
gridPOResults.Visible = true; //Show PO Grid
numOrderDtl_OrderNum.Value = (0);
numOrderDtl_OrderLine.Value = (0);
numOrderDtl_TotalReleases.Value = (0);
epiTextBoxPORefNum.Text = txtOrderHed_PONum.Text;
DynamicQueryAdapter dqa = new DynamicQueryAdapter(oTrans);
dqa.BOConnect();
QueryExecutionDataSet qeds = dqa.GetQueryExecutionParametersByID("GS_Order_Detail_ParamsPO");
qeds.ExecutionParameter.Clear();
qeds.ExecutionParameter.AddExecutionParameterRow("POParam", epiTextBoxPORefNum.Text, "nvarchar", false, Guid.NewGuid(), "A");
dqa.ExecuteByID("GS_Order_Detail_ParamsPO", qeds);
gridPOResults.DataSource = dqa.QueryResults.Tables["Results"];
//Order - PO Grid Refreshes Text Box
private void gridPOResults_AfterRowActivate(object sender, System.EventArgs args)
epiTextBoxPORefNum.Text = "cab123456"; //This is just hard coded right now because I have no idea how to say column "OrderHed_PONum" from the grid.
