You can set the standard cost at any time by doing a Cost Adjustment under Inventory Management > Cycle Count Processes.
Under Engineering > Reports there is a BOM Cost report – if you need a roll up.
You can also right click on the Part revision and go to Method Tracker. In Method Tracker under actions -  view cost.Â
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of tom.sederquist@...
Sent: Wednesday, April 30, 2014 9:10 AM
Subject: [Vantage] Duplicating a Part (Cost Roll-up)
When you create a standard costed assembly part do you have to use the costing workbench and perform a cost roll-up in order to generate cost information for the part upon a transaction to inventory?
