For some reason this week, duplicate part has begun giving this error. It only gives this error on Live and not on our Test server. I ran traces on both Live and Test and it is following the same steps up through DuplicatePart at which point it stops on Live with the error and Test continues to PartExists and then GetByID. There are three BPMs on Duplicate which were written months ago and have not changed. They are exactly the same on Live and Test. I also disabled all Method and Data Directives I have added in the last 3 months to make sure none of those are interfering. Even with those all disabled, I receive the same error.
Error
Business Layer Exception
Target Part number already exists.
Error Detail
Description: Target Part number already exists.
Program: Erp.Services.BO.Part.dll
Method: DuplicatePart
Line Number: 5647
Column Number: 17
Server Trace Stack: at Erp.Services.BO.PartSvc.DuplicatePart(String sourcePartNum, String targetPartNum, String targetPartDescription, String configuratorMode, String configID, String configDescription, String configType) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Services\BO\Part\Part.cs:line 5647
at Epicor.Customization.Bpm.BO99368248778347AA929C26276C67372C.DuplicatePartImpl.ExecuteBase(DuplicatePartParameters parameters)
at Epicor.Customization.Bpm.MethodCustomizationBase2`3.RunDirectives(TParam parameters) in c:\_Releases\ICE\3.1.500\Current\Source\Server\Internal\Lib\Epicor.Customization.Bpm\MethodCustomizationBase2.cs:line 218
at Epicor.Customization.Bpm.CustomizationBase2`3.Execute(TParam parameters) in c:\_Releases\ICE\3.1.500\Current\Source\Server\Internal\Lib\Epicor.Customization.Bpm\CustomizationBase2.cs:line 77
at Epicor.Customization.Bpm.BO99368248778347AA929C26276C67372C.PartSvcCustomization.DuplicatePart(String sourcePartNum, String targetPartNum, String targetPartDescription, String configuratorMode, String configID, String configDescription, String configType)
at Erp.Services.BO.PartSvcFacade.DuplicatePart(String sourcePartNum, String targetPartNum, String targetPartDescription, String configuratorMode, String configID, String configDescription, String configType) in C:\_Releases\ERP\UD10.1.500.18\Source\Server\Services\BO\Part\PartSvcFacade.cs:line 812
at SyncInvokeDuplicatePart(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in C:\_Releases\ICE\3.1.500.18\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in C:\_Releases\ICE\3.1.500.18\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 28
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in C:\_Releases\ICE\3.1.500.18\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.SecurityChannelListener`1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.PartImpl.DuplicatePart(String sourcePartNum, String targetPartNum, String targetPartDescription, String configuratorMode, String configID, String configDescription, String configType)
at Erp.UI.App.PartEntry.PartTransaction.Duplicate()
