I think I do.. You are in RMA processing. On the Credit tab, when you
hit 'Add' it will bring up the form Invoice Entry maintenance. I'm
assuming you've customized the invoice entry form. This is easily taken
care of through the Sub Process Maintenance and Process Calling
Maintenance screens. I sent LeAnn a detailed instruction on how to do
that exact customization, with screen shots.
Rob Bucek
Manufacturing Engineer
PH: (715) 284-5376 ext 3111
FAX: (715)284-4084
http://www.dsmfg.com/>
(Click the logo to view our site) <
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Art Nito
Sent: Thursday, October 15, 2009 3:37 PM
To:
Subject: Re: [Vantage] Vantage: Need Help on a Form called from another
Form
Rob,
That I can do, but you do not understand.
This is not a menu item.
This is a form called from another form, activated from a control
button.
Art Nito
rbucek@... <mailto:rbucek%40dsmfg.com> >
To:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
Sent: Thu, October 15, 2009 10:27:02 AM
Subject: RE: [Vantage] Vantage: Need Help on a Form called from another
Form
You go into menu maintenance and find the form you customized and assign
the customization name there. So if it was the Invoice entry screen you
customized you would open under menu maintenance in the tree view
financial management/accounts receivable/general operations/Invoice
Entry and under the customization drop down choose your customization.
Save, and restart your client vantage session. You should then see your
customization the next time you open that form.
Rob Bucek
FAX: (715)284-4084
http://www.dsmfg com/>
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On
Behalf
Of Art N
Sent: Thursday, October 15, 2009 11:26 AM
To: vantage@yahoogroups .com
Subject: [Vantage] Vantage: Need Help on a Form called from another Form
Hi,
I'm a programmer but new to Vantage customization. I need help on a form
called from another form. I customized a form and saved and exported it
as a different version. I know how to set versions on Menu Maintenance
but not this process calling.
Where do I set this to call my new custom form?
It says:
Process Calling
process key: Epicor.Mfg.UI. ARInvoiceEntry
calling app: Epicor.Mfg.UI. RMAProcEntry
The form though is ARInvoiceEntry. RMACreditUpdForm . We are on 408b.
Thank you much for any response.
~Art N
