Drag/Drop to Attachments
I have an user who can not drag and drop his attachments but he can attach them via the browse function. Everyone else can drag and drop. Any ideas?
You started Epicor UI with elevated rights. Windows does not allow DnD in that case.
@Olga Elevated rights? Sorry, I’m not following.
HOw do you start Epicor? is there is a shortcut? Do you run it as administartor?
Shortcut. AS in Admin in windows-correct? If so, I do not think they are, I’d have to double check their computer. But I’m fairly positive they are not. Yet, I could be wrong.
Correct. There is also Properties\Shortcut\ Advanced… button, Run as administrator can be set there as well.
So he is not currently running as Admin, it is set to run in separate memory space.
is fine. DnD for attachments works in that case.
