DoNotShipBeforeDate 8.03x
We've customization for Packing Slip form when trying to ship part before Ship By date shipper is going to see Window which tells that it is to early shipping.
I think you should be able to use BPM to create alert or to stop shipping if date is to early.
I hope this helps a little.
Thanks.
Bart.
Sent: Thursday, May 21, 2009 11:15:47 AM
Subject: Re: [Vantage] DoNotShipBeforeDate 8.03x
Randy
You can add date controls to see the data (and edit it) on forms.
Rob
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Thursday, May 21, 2009 8:41:24 AM
Subject: RE: [Vantage] DoNotShipBeforeDate 8.03x
It's in Order Detail but you can only see it in list view - not detail
view.
Randy Weber
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of DD
Sent: Wednesday, May 20, 2009 2:55 PM
Where did you find that field.
I do not see it in 8.03 or 9.04.
I think it might be for EDI from the customer.
--- On Wed, 5/20/09, Randy <rweber@tlcelectron i cs.com
Subject: [Vantage] DoNotShipBeforeDate 8.03x
To: vantage@yahoogroups .com <mailto:vantage% 40yahoogroups. com>
Date: Wednesday, May 20, 2009, 1:16 PM
I just noticed a new field in order detail called DoNotShipBeforeDate .
I had hoped that this would prevent a shipment entry from completing if
they tried to ship before this date, but when I tested this, it did not
warn me or anything.
Am I missing something? Is anybody else using this feature? Do I need to
use reporting or customization to make use of this feature?
Randy Weber
I just noticed a new field in order detail called DoNotShipBeforeDate.
I had hoped that this would prevent a shipment entry from completing if they tried to ship before this date, but when I tested this, it did not warn me or anything.
Am I missing something? Is anybody else using this feature? Do I need to use reporting or customization to make use of this feature?
Randy Weber
Â
Randy Weber
Randy,
It doesn't natively inhibit shipment but can provide for visual cues & warnings at critical steps in your entire order life cycle process (if leveraged for use in various application customizations).
I suppose you could also use it as a test (against ShipHead.shipdate) within a before_adapter_method triggered subroutine (in shipment entry - check the application for what method is called to add a new shipdetail) to prevent adding the shipment detail if ShipHead.ShipDate <= OrderDtl.DoNotShipBeforeDate.
Probably some way to do that from the server side with a BPM as well I would imagine.
RobÂ
Â
Sent: Wednesday, May 20, 2009 2:16:14 PM
Randy Weber
Its used in the Demand Management module as part of the Contract Management/EDI setup. It won't do anything for you without this module
Date: Wednesday, May 20, 2009, 2:16 PM
Randy Weber
view.
Randy Weber
Of DD
Randy Weber
Just a thought could you create a BPM using that field that would either
stop or alert the user if the date was > today's date?
Randy
Rob
view.
Randy Weber
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of DD
--- On Wed, 5/20/09, Randy <rweber@tlcelectroni cs.com
Randy Weber
