We use a VBForm field on the job operation record. I then print report
builder reports for receiving logs, etc... with the actual measurements and
comments from a given test. Some of our tests are completed after approval
is given. Our problem is we may do a 600 hour salt spray test which is
completed weeks after the product ships and sometimes accounting has closed
the job before all test results are entered.
Patrick J. Winter
Information Services Manager
sSc Specialty Screw Corporation
Vantage 4.00.901
Sent: Wednesday, December 20, 2000 12:04 PM
To: vantage@egroups.com
Subject: [Vantage] Documenting Inspection Data
We are setting up an ISO 9002 quality system.
Does anyone know if you can enter actual dimensions for receiving and
in-process inspections into a Vantage data base. And can you retrieve this
data as a quality record.
Patrick J. Winter
Vantage 4.00.901
