I would be curious to find out if anyone is using a document management system other than ECM or SharePoint with Kinetic. If you are, please let us know what you are using and how it is working for you.
What use case are you trying to address ?
The primary consideration is Quality document control, but we what something flexible enough to work company wide.
QC documents are generally PDF, images or text logs
Depending on the level of complexity in document management, version control, access rights etc, your choices can range from saving into a local folder, publishing to cloud(S3 or Azure) or integrate to even Headless CMSs
We are just saving to a local shared drive as of now.
