That worked....was a bit confusing because when you do a Query, you have to look at PlantWhse for the Primary Bin, but in the DMT, it is available in the Part Warehouse. So I didn't even bother to look there.
Miguel A. Santillan
Compass Components, Inc.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Miguel Santillan
Sent: Wednesday, October 03, 2012 2:32 AM
Subject: RE: [Vantage] Re: DMT Tool and PrimBin
Thanks, I will test that out.
Miguel A. Santillan
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of cubcrafters_it
Sent: Tuesday, October 02, 2012 3:02 PM
Subject: [Vantage] Re: DMT Tool and PrimBin
Yeah, you can set the Primary Bin using Part Warehouse. The field is called PrimBinNum.
Miguel A. Santillan
Miguel A. Santillan
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Miguel Santillan <msantillan@...<mailto:msantillan@...<mailto:msantillan@...%3cmailto:msantillan@...>>> wrote:
> Sorry, I meant PrimaryBin
> Miguel A. Santillan
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Brian Roberts
> Sent: Tuesday, October 02, 2012 12:27 PM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Subject: RE: [Vantage] DMT Tool and PrimWhse
> Yes, via updating PartPlant. If you're adding PartPlant records and
> specify the primary warehouse it will create the warehouse for you, if
> you're updating afterwards I think you need to have created the PartWhse
> record first.
> Brian.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf
> Of Miguel Santillan
> Sent: Tuesday, October 02, 2012 1:38 PM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Subject: [Vantage] DMT Tool and PrimWhse
> Can I update the Primary Warehouse via DMT?
> Regards,
> Miguel A. Santillan
