DMT to E10 BOO ECOOpr table
This migration is going to be the death of me… I am using DMT to import the BOO and I am getting the error “(ECOOprBeforeUpdate) Table ECOOpr A valid primary production operation detail is required”
I don’t see ECOOpr as a column in the template or the table. Did I miss a set up somewhere? Any suggestions of where to look are appreciated :slight_smile:
Melissa
I have made the template only the fields required by the DMT (company,part number, rev, op#, op code, pland, eco group) and am not getting the error anymore. I am going to try importing bit by bit…
Melissa,
On the Operation record, you need to have either a Resource, a Resource Group, or a Capability defined.
If it’s any consolation, uploading the BOO is almost always a nightmare. If it isn’t, you’ve probably done something wrong!
Ernie Lowell
Hi Melissa,
Did you ever figure this one out? I am having the same issue using a template we had that worked fine back on E9 but not on E10.
Bryan
Lol… I Entered the very minimum as required by the DMT template. I then added a few fields at a time to update. I eventually hit an error that even Epicor said they couldn’t figure out and I needed to reset the database and start loading all the data again from the beginning.
For anyone who finds this in the future.
The error is being caused by the inclusion of ‘PrimarySetupOpDtl’ or ‘PrimaryProdOpDtl’ columns. Remove them and that will stop DMT from falling over. What I would reccomend is then re-adding these columns back into your file, re-running the DMT import but only with Update selected.
Joe
Thanks Joe. Ran into the same thing and followed your instructions and it worked perfectly!
