I’m trying to use DMT to create a plant record.
Pretty barebones DMT but I’m getting this error, this is not a field in the DMT. I can also create these plant records in the application without an error.
I got it figured out, I was not in the correct company. It’s been a while since I had that issue. For anyone who doesn’t know, if you log out of Epicor, DMT will look at the last company you used and log you into DMT under that company.
