Trying to import Bill of Operations for parts to include a resource. When I import it only imports the resource group but not the resource specified in the ECOOpdtl#ResourceID Column.
I suspect because the operation input for the Opcode column has only a resourceGroup for scheduling requirement .
I can manually checkout the part and then tie it to specific resource.
Any column I am missing that should be there to have the resource in the Bill of Operations?
Sequence is important. Make sure your ECOOpDtl#ResourceGrpID appears as a column prior to ECOOpDtl#ResourceID. Both should appear after ECOOpDtl#OprSeq and ECOOpDtl#OpDtlSeq
