I am Trying to run a DMT for PO Receipt Combined. When I create the template I receive the error “A Valid PO is Required.” I am able to manually receive these POs in Epicor and when I check the Database the data matches what I have in the DMT Load Files.
For a second run I tried just DMT’ing the PO Receipt Header which also came back with the same error “A Valid PO is required” When I look up this PO in Epicor it definitely exists. When I tried going into Receipt Entry to just created the header manually that also worked. Then I looked at the database and the data matched my DMT Load Files.
A Strange Third test that didn’t error, but also didn’t work was when I Tried a DMT Load for PO Receipt Header but in the VendorNumVendorID field I used the VendorNum the DMT appeared to be successful without error, however the record did not load into Epicor.
I contacted Epicor Support and they said they were able to run successfully in their Test environment and that I’d have to contact their Professional Servies Consultants. Before I went that route I wanted to see if anyone has successfully done this or could maybe provide me some insight on something I could be doing wrong.
Thank you!
