I am trying to put parts into our system using the dmt and keep getting this error. I have the UOM and Classes in, but it still won’t allow me to do anything.
Table: IUM Msg: Primary Unit of measure for Inventory not found for Class:COUNT UOM:EA Table: PUM Msg: Primary Unit of measure for Purchasing not found for Class:COUNT UOM:EA Table: SalesUM Msg: Primary Unit of measure for Sales not found for Class:COUNT UOM:EA Table: NetVolumeUOM Msg: Unit Net Volume Unit of measure not found for Class:VOLUME UOM:GA Table: PartLengthWidthHeightUM Msg: Unit of measure not found for Class:LENGTH UOM:FT
I used Epicor’s DMT templates when I was adding parts, boos and boms. If you search EpicWeb for dmt templates you can find what they use in the dmt labs. Maybe there is a field(s) you need to add.
When you set up the UOM Classes did you add the individual UOMs as UOM conversions within the classes? Epicor is saying it can’t find those UOMs within the classes you specified in the Part template.
I figured it out. Feel dumb, BUT…It wasn’t EA for each. It was EACH. Once I changed it and added in a few other UOM that were forgotten, everything worked.
