Hi
Is there a dmt method to add a new menu? I have everything set out in excel but its taking a looong time to manually add each menu folder, sub folder them function…
Any speedy process would be graciously received
Hi
I assume you searched for it in DMT first?
If you are building a whole new menu, I would be cautious…
One of the big reasons as to not do it is that it breaks any documentation/learning around Kinetic.
Im using that currently and the manual process is more than tedious…
We dont use kinetics. an audit has prompted a menu structure which is robust and from what has been completed, its easy to navigate. its just the time it takes to add them in. I feel that a good excel sheet could be created quickly then uploaded but its easy to say and not so easy find out of i can do that or not
actually sorry i didnt see that in DMT
search on Epiusers, I am sure someone has posted a spreadsheet already to do this… Jus can’t remember who.
I referred to Epicor ERP as “Kinetic” The base menu structure (for the most part) is the same.
