DMT help
Hello, I am trying to DMT data into Epicor. At times I am getting an error that says these fields are “Read Only” I am not sure what that means and why it is doing that.
You’ll probably have to elaborate more than that to get any kind of answer. What are you trying to update?
The best is to use the Template Builder, where it will show you What are the required fields. Probably, you are including the fields in your CSV that are system reserved.
Could you just provide more details ?
Hi,
I have seen this before when the case of the column header isn’t correct.
For example, ‘company’ instead of ‘Company’.
Cheers,
Andrew.
