DMT hangs on Payroll Check Hours
Has anyone run into an issue with the DMT payroll check hours where it is set up correctly but then when you go to run and import it into payroll group and it just hangs. no processing, no errors, and you also cant cancel the import. i wouldnt expect the DMT to take longer than a few minutes to import a few check lines into a payroll group.
also no user is “tying” up the group
