This is the error I am receiving, I am fully licensed.
2021-04-13T09:31:59 PartNum 10000 Plant MfgSys 10000 MfgSys Table: Msg: Your software license does not allow this feature.
I am getting the above error when loading PartPlant records utilizing the DMT with the ADD NEW check box selected. I am using the same template I’ve used many times prior when build TEST database, but previously, I have always had the ADD NEW and UPDATE check boxes selected and have no issues.
I can reload the data to the DMT, select both ADD and UPDATE and the DMT starts the load with out issues. It is only when I have the ADD New check box selected.
Prior to the PartPlant attempt, I had just used the DMT to "ADD New’ to the parts table and had no issues when I used the ‘ADD New’ check box exclusively.
Has anyone else experienced this issue? Any resolutions?
If I recall correctly, the PartPlant record gets created automatically for your primary site when you create the Part record. If you don’t have a multi-site license, Epicor is not going to allow you add additional PartPlant records - so you should need to have the update checkbox selected when updating the PartPlant records with the DMT tool.
Thank you for the response, I came to the same conclusion after I tested a little more with part creation and saw that the part Plant record was being created at the time the part was created, so it makes sense. The message could be a little more specific to that and I made have made the connection a little sooner.
Welcome to DMT! I still remember creating and testing playlist after playlist in DMT for our implementations. So many quirks, so many things that seemingly didn’t make sense. This forum helped so much with that whole process…
