DMT - Change Company
Is there a way to change which company is listed in the status bar in DMT? Or does it even matter?
JOE ROJAS
Epicor Applications Manager
VENTION MEDICAL + DESIGN & DEVELOPMENT
Advancing Your Innovations For Health
261 Cedar Hill Street | Marlborough, MA 01752
DIRECT: 508.597.1392 x1625 | MOBILE: 774.826.9245
EMAIL: JoRojas@ventionmedical.commailto:JoRojas@ventionmedical.com | WEB: ventionmedical.com http://www.ventionmedical.com/
THINK QUALITY. BE QUALITY. GO BEYOND.
This communication may contain information that is confidential, proprietary or exempt from disclosure, and is intended only for the use of the individual and/or entity it is addressed to. If you are not the intended recipient, please note that any other dissemination, distribution, use or copying of this communication is strictly prohibited. If you have received this message in error, please notify the sender immediately by telephone or by return e-mail, and delete this information from your computer.
No, and it doesn’t really matter as long as you include the Company ID in all your DMT loads. You can even load into multiple companies with the same load. Also look out for Plant/Site specific data and include the Plant/Site ID when possible.
When you login to DMT it uses the Company you last exited Epicor under.
The DMT session has the same access and permissions as the Epicor user it was logged into with.
Also all transactions and record changes will have that user id if there is a field for it.
For these reasons you might want to create a DMT only account, makes it easier to explain how something happened.
Excellent.
Thanks for the reply Rick.
JOE ROJAS
Not sure why, but occasionally DMT will default to:
We don’t even have an environment named Golden, nor is the connection URL valid for our domain.
I know the environment is not the same as the company, but some of DMT’s assumptions make me nervous.
I’ve never seen this happen before Calvin. My guess is it’s the test environment defaults or something if it can’t load the local config file. Though it should error.
One thought, where is your DMT.exe file located, it usually uses that location as an app-server home-base for finding the correct config file. I had to make sure that if I wanted to open DMT from say the desktop that I use a shortcut and that the Start In value is within that app server.
I would recommend that you report this to Epicor Support though.
Golden is an internal testing server they’ve used / hard coded / defaulted. It shouldn’t show up as long as it can read your environment. I’ve ran into that one a few times.
Rick - I have reported it.
The worst time was when I had “Single Sign-On” selected to speed up launching the program. But when it defaults to “Golden” the SSO fials, and the program exits. Never giving me the chance to change the environment from Golden to our Production or Test DB.
Jose - I have two shortcuts for DMT. One for the Production DB, and one for our test DB. Both show “Golden” as an option in the drop down. Every single time.
Snippet of DMT launched by the shortcut for our test DB (MC-UAT)
Calvin,
Do you by chance have a golden config file in your config subfolder you are calling DMT from? That is how I usually see the environment combo populated.
Ross
DMT stores the last config file name used in the %APPDATA%\DotNetIt\DMTv10.ConfigAppSettings file. DMT defaults to this config file on the login page. If this config file does not exist then it defaults to Default.SysConfig. If this does not exist then it defaults to the 1st config file in the Config folder under the Epicor client folder. The %APPDATA%\DotNetIt\DMTv10.ConfigAppSettings file is human readable and is recreated on DMT exit, so can safely be deleted.
The only time I’ve run into an issue is when I’ve created a new company before requesting the new license. If you’re not licensed for the last company you exited, DMT will not run. Switch over to a licensed company and you’re fine. A “no brainer” when it’s written out but I’ve come across it before on a multi-company instance.
