When using DMT for BOO or BOM updates, has anyone found way to add “Description of Change” which would then be visible within the Audit Log of the Revision, versus having “Imported” default into that from the DMT push?
Obviously when checking out/in manually, you can enter comments into the Description of Change but when using DMT, I haven’t found a way to do this - does anyone know the secret?
