"Scrap" in MES reduces the job operation quantity and absorbs the
non-conforming part into the total job cost and the remaining good
parts.
Non conformances moved through Inspection and then rejected via DMR
process are removed from the system...
The only standard reports available would be the material transaction
detail report or the Inventory WIP Reconciliation report where you can
search for transaction type DMR-REJ for a given date range.
_____
Of Ari Footlik
Sent: Wednesday, February 11, 2009 8:52 AM
Subject: [Vantage] DMR Rejects
Do manufactured-parts become "Scrap" when they are failed by Inspection
Processing and rejected from DMR? Is the end result the same as if they
had been entered as "Scrap" in MES?
Once they are DMR-rejected, are they removed from the quantity-counts in
the system? Can I get a list of every part that has been handled this
way?
Thanks.
--Ari
NOTICE OF CONFIDENTIALITY: This e-mail message, including attachments, is for the sole use of the intended recipients and may contain confidential and privileged information. If you are not an intended recipient, please contact the sender by reply e-mail and destroy all copies of this message, including attachments. Any unauthorized review, use, disclosure or distribution is prohibited.
parts.
_____
Of Ari Footlik
way?
Thanks.
--Ari
