Below is a piece of code I wrote for an external BPM. Basically, it should work like this query in SQL:
SELECT pc.StdMaterialCost, pc.StdMtlBurCost, p.ShortChar01 AS SkuType, od.PartNum
FROM
OrderDtl od
LEFT OUTER JOIN
Part p
ON
p.PartNum = od.PartNum
AND
p.Company = od.Company
LEFT OUTER JOIN
PartCost pc
ON
pc.PartNum = od.PartNum
AND
pc.Company = od.Company
WHERE
od.Company = 'COMP01'
AND
od.OrderNum = 700118
AND
pc.CostID = '1'
AND
p.ShortChar01 NOT IN ('G', 'X')
The query works and returns me the exact results I expected. So when I transformed to C# code it looked like this:
using System;
using System.Data;
using System.Data.SqlClient;
using System.Linq;
using System.Linq.Expressions;
using System.ServiceModel;
using Epicor.Data;
using Ice;
using System.Collections.Generic;
using System.IO;
using System.Net;
using System.Text;
using System.Threading.Tasks;
namespace SalesOrder.BPM
public partial class Update
public void StdCostValidation(Erp.Tablesets.SalesOrderTableset ds)
var ctx = new Erp.ErpContext();
var orderHed = ds.OrderHed.First();
var listOfCosts = ctx.OrderDtl.With(LockHint.NoLock).Join(ctx.Part.With(LockHint.NoLock),
dtl => new { dtl.PartNum, dtl.Company },
part => new { part.PartNum, part.Company },
(dtl, part) => new { dtl, part })
.Join(ctx.PartCost.With(LockHint.NoLock),
dtlPart => new { dtlPart.dtl.PartNum, dtlPart.dtl.Company },
cost => new { cost.PartNum, cost.Company },
(dtlPart, cost) => new { dtlPart, cost })
.Where(a =>
a.dtlPart.part.ShortChar01 != "G" &&
a.dtlPart.part.ShortChar01 != "X" &&
a.cost.CostID == "1" &&
a.dtlPart.dtl.Company == orderHed.Company &&
a.dtlPart.dtl.OrderNum == orderHed.OrderNum)
.Select(x => new StandardClass
PartNum = x.dtlPart.part.PartNum,
SkuType = x.dtlPart.part.ShortChar01,
TotalStdCost = (x.cost.StdMaterialCost + x.cost.StdMtlBurCost)
.ToList();
foreach (var cost in listOfCosts)
if (cost.TotalStdCost == 0M)
throw new BLException(string.Format("Total standard cost cannot for {0} be zero", cost.PartNum));
public class StandardClass
public string PartNum;
public string SkuType;
public decimal TotalStdCost;
The problem is, everytime I run this code I get the error:
Distributed transaction completed. Either enlist this session in a new transaction or the NULL transaction.
What am I doing wrong?
Full error log:
Application Error
Error Detail
Message: An error occurred while executing the command definition. See the inner exception for details.
Inner Exception Message: Distributed transaction completed. Either enlist this session in a new transaction or the NULL transaction.
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
at System.Data.EntityClient.EntityCommandDefinition.ExecuteStoreCommands(EntityCommand entityCommand, CommandBehavior behavior)
at System.Data.Objects.Internal.ObjectQueryExecutionPlan.Execute[TResultType](ObjectContext context, ObjectParameterCollection parameterValues)
at System.Data.Objects.ObjectQuery`1.GetResults(Nullable`1 forMergeOption)
at System.Data.Objects.ObjectQuery`1.System.Collections.Generic.IEnumerable<T>.GetEnumerator()
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
at Epicor.Data.DBExpressionCompiler.GetResult[TContext,TQuery,TResult](Func`3 executeQuery, Cache cacheSetting, TContext dataContext, TQuery query) in D:\_Releases\ICE\3.1.500.36\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 425
at Epicor.Data.DBExpressionCompiler.InvokeList[TContext,TQuery,TResult](Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TContext dataContext, Func`2 getDataCacheKey, Func`2 compileQuery, Func`3 executeQuery) in D:\_Releases\ICE\3.1.500.36\Source\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 159
at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass2_0`4.<Compile>b__0(TContext context, TArg1 arg1, TArg2 arg2) in D:\_Releases\ICE\3.1.500.36\Source\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 82
at Erp.Services.BO.SalesOrderSvc.chkComplianceOrderFail(Int32 orderNum, String& compliantMsg) in C:\_Releases\ERP\UD10.1.500.36\Source\Server\Services\BO\SalesOrder\SalesOrder.cs:line 13185
at Erp.Services.BO.SalesOrderSvc.MasterUpdate(Boolean lCheckForOrderChangedMsg, Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cCreditShipAction, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel, SalesOrderTableset& ds) in C:\_Releases\ERP\UD10.1.500.36\Source\Server\Services\BO\SalesOrder\SalesOrder.cs:line 21046
at Erp.Services.BO.SalesOrderSvcFacade.MasterUpdate(Boolean lCheckForOrderChangedMsg, Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cCreditShipAction, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel, SalesOrderTableset& ds) in C:\_Releases\ERP\UD10.1.500.36\Source\Server\Services\BO\SalesOrder\SalesOrderSvcFacade.cs:line 2401
at SyncInvokeMasterUpdate(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.InnerInvoke(Object instance, Func`2 func) in D:\_Releases\ICE\3.1.500.36\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 59
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func) in D:\_Releases\ICE\3.1.500.36\Source\Framework\Epicor.System\Hosting\OperationBoundInvoker.cs:line 47
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) in D:\_Releases\ICE\3.1.500.36\Source\Framework\Epicor.System\Hosting\Wcf\EpiOperationInvoker.cs:line 23
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
Inner Trace:
: at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior)
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.SalesOrderImpl.MasterUpdate(Boolean lCheckForOrderChangedMsg, Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cCreditShipAction, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel, SalesOrderDataSet ds)
at Erp.Adapters.SalesOrderAdapter.MasterUpdate(Boolean lCheckForOrderChangedMsg, Boolean lcheckForResponse, String cTableName, Int32 iCustNum, Int32 iOrderNum, Boolean lweLicensed, Boolean& lContinue, String& cResponseMsg, String& cCreditShipAction, String& cDisplayMsg, String& cCompliantMsg, String& cResponseMsgOrdRel)
at Erp.UI.App.SalesOrderEntry.Transaction.Update()
Inner Exception
