Each job has to be done in *perfect* order and leaves no room for error.
If one thing is out of sequence or you have to adjust a quantity along
the way - good luck! We are learning. Do not change the job quantity
after you've started manufacturing on it either. You'll create more
headaches.
Of course we do not live in a *perfect* world so we are seeing variances
that shouldn't be variances constantly.
Sue
Of Mike Lowe
Sent: Wednesday, March 15, 2006 1:39 PM
Subject: RE: [Vantage] Digest Number 3739
I think I would be more inclined to say it's the shipment of product
against the job and lagging job transactions causing the problem.
especially since the COS/WIP capture will create a variance whether the
job is closed or not under certain conditions.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Vesa Anttila
Sent: Wednesday, March 15, 2006 1:06 PM
Hi,
We're on Vantage 6.10. Running the COS/WIP Capture causes a large number
of MFG-VAR entries to occur. These items clear through the variance
account & are a big problem for us since we do not use standard costing.
Epicor advises us that this problem is caused by a mismatch in timing
between closing of the sales order and the related jobs.
Do you agree with this assessment?
How do you ensure in your organizations that the sales orders and the
related jobs get closed within a reasonable time period?
Vesa Anttila
Controller
Living Color Enterprises, Inc.
6850 NW 12th Avenue
Ft Lauderdale, FL 33309
Tel : (954) 861-2802 Direct
Fax: (954) 978-3811
e-mail: vanttila@...
Website: www.livingcolor.com
Sent: Wednesday, March 15, 2006 2:51 PM
Subject: [Vantage] Digest Number 3739
There are 10 messages in this issue.
Topics in this digest:
1. Re: Syntax Error 7587
2. Re: [6.1] Global Finite Scheduling
3. RE: Syntax Error 7587
4. Vntg 6.0 Help and Content Filter
5. RE: Server Specs
6. indirect labor codes
7. RE: Syntax Error 7587
8. Inventory Average-Cost
9. RE: Inventory Average-Cost
10. RE: Syntax Error 7587
________________________________________________________________________
Message: 1
Date: Wed, 15 Mar 2006 17:25:24 -0000
Subject: Re: Syntax Error 7587
What application are you attempting to open this table in?
Read Uncommitted is the Default Isolation level that support instructs
us to use. It allows you to read but not write to the DB.
It prevents locking errors.
If you changed the setting but did not leave and re-enter your
application the change would probably not take effect.
Brian Stenglein
Clow Stamping Co.
headaches.
Sue
Of Mike Lowe
Of Vesa Anttila
Hi,
Vesa Anttila
Controller
6850 NW 12th Avenue
Fax: (954) 978-3811
5. RE: Server Specs
Message: 1
Brian Stenglein
Clow Stamping Co.
--- In vantage@yahoogroups.com, "Ben Belzer" <bbelzer@...> wrote:
> I switched it over to read uncommitted and no luck. Syntax Error
7587.
> Any other ideas? It would be most appreciated...
Behalf
> Of Kennedy, Jim
> Sent: Wednesday, March 15, 2006 5:27 AM
> Subject: RE: [Vantage] Syntax Error 7587
> Open your ODBC Data Source Administrator, select the Vantage ODBC
driver
> (Most probably identified as MERANT 3.60 32-BIT Progress SQL92 if
you're
> using progress DB). Then click on the configure button, select the
> "Advanced" tab and change the "Default Isolation Level" to "Read
> Uncommitted"
> You might also want to increase the "Fetch Array Size" while your in
> that screen as well.
> I know certain users like to use various size fetch arrays, but
you'll
> find out what works best for you...
> Jim Kennedy
> Manager, Information Technologies
> Firstmark Aerospace Corporation
> 1176 Telecom Drive
> Creedmoor, North Carolina 27752
> Office: (919) 956-4264
> FAX: (919) 682-3786
> Cell: (919) 697-9410
> jkennedy@...
> www.firstmarkaerospace.com
> www.firstmarkcorp.com
Behalf
> Of Ben Belzer
> Sent: Tuesday, March 14, 2006 5:47 PM
> Can you please explain how to switch it to read uncommitted?
> Thanks!
Behalf
> Of Kennedy, Jim
> Sent: Tuesday, March 14, 2006 11:53 AM
> The PartTran is almost always being accessed by a number of
programs.
> I found that as long as I'm in the "read uncommitted" mode with my
ODBC
> it won't fail me.
> Jim Kennedy
> 1176 Telecom Drive
> FAX: (919) 682-3786
> jkennedy@...
Behalf
> Of RICH WAGNER
> Sent: Tuesday, March 14, 2006 2:49 PM
> I encounter the same error
> From: Ben Belzer [mailto:bbelzer@...]
> Sent: Tuesday, March 14, 2006 2:44 PM
> Subject: [Vantage] Syntax Error 7587
> I am trying to access the PartTran table using ODBC and I am
getting a
> syntax error 7587.
> Has anyone ever encountered this? This is the only table that
gives me
> this error.
> Thanks!
> Ben Belzer
> IT Manager
> TCI Precision Metals
> 800.234.5613.W
> 310.323.1255.F
> bbelzer@... <mailto:bbelzer@...>
> www.tciprecision.com < http://www.tciprecision.com/>
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> Yahoo! Groups Links
must
access. )
Builder
> Yahoo! Groups Links
must
access. )
Builder
> Yahoo! Groups Links
must
access. )
Builder
> Yahoo! Groups Links
must
access. )
Builder
> Yahoo! Groups Links
Message: 2
Date: Wed, 15 Mar 2006 17:37:42 -0000
Subject: Re: [6.1] Global Finite Scheduling
I haven't used it in anger for a bit. Didn't use the MRP at all,
there wasn't really an issue with material requirements being
automatically suggested/calculated. Probably, should have made that
clearer.
--- In vantage@yahoogroups.com, "Clint Muhlestein" <cmuhlestein@...>
wrote:
> Brychan how often do you run Global Finite Scheduling and do you
use the
> MRP module ?
> From: brychanwilliams [mailto:brychanw@...]
> Sent: Wednesday, March 15, 2006 10:07 AM
> Subject: [Vantage] Re: [6.1] Global Finite Scheduling
> Ben,
> Is this still the case when the option is not ticked , in
> company/job management?
> --- In vantage@yahoogroups.com, "Ben Belzer" <bbelzer@> wrote:
> > Keep in mind that in 6.1 Vantage schedules into the past on
> operations
> > that have already started. 8.0 is supposed to change this.
> > We use Global Finite Scheduling and have switched from finite
> capacities
> > to infinite. The problem is that infinite would be great for
the
> shop,
> > and finite is great for sales (to quote accurate lead times).
We
> still
> > aren't sure which we like more.
On
> Behalf
> > Of progress92000
> > Sent: Wednesday, March 15, 2006 7:58 AM
> > This is a great guide for me.
> > Thanks,
> > Nam
> > --- In vantage@yahoogroups.com, "brychanwilliams" <brychanw@>
> > wrote:
> > > Morning,
> > > There are many different levels of functionality in Global
> Finite
> > > Scheduling.
> > > 1) The Basic Level - No Finite capacities. This will run just
> > based
> > > on due dates and try to backward and forward schedule as the
> best
> > it
> > > can.
> > > 2) Limited Finite capacity - Some workcenters will have finite
> > > capacity. So it will try and schedule the earliest due dates
> first
> > > and then take into account the finite capacities.
> > > 3) Full finite capacity - all workcenters have finite capacity.
> > > Into the mix goes priority codes which basically gives a
> capacity
> > > where possible to those jobs with a higher priority code.
> > > In terms of trying to implement global finite scheduling you
can
> > > split it into two categories but supplement each other.
> > > Structures
> > > 1. Ensure Workcenters and Operations are accurate
> > > a) Number of Machines
> > > b) Hours per machine
> > > c) Finite or not.
> > > 2. Calendars are accurate.
> > > Processes
> > > 1. Ensure that job bookings are timely.
> > > 2. Ensure initial schedule is reasonable
> > > 3. Ensure that there is a scheduling process for prior and
post
> > > global rescheduling.
> > > 4. Ensure that there is a process for updating the shop floor
> with
> > > the new schedule.
> > > In terms of implementation;
> > > Do a lot of testing, so if you decide that you will reschedule
> > every
> > > monday, take a copy of the database every monday and do a
> > reschedule
> > > on that etc.
> > > I would recommend that you do this a couple times with your
> > current
> > > configuration to assess how accurate it is.
> > > Remember that the global rescheduling is good but it is not a
> self
> > > contained process , the scheduler will need to manage it so
> > training
> > > and additional will be requried.
> > > The other side benefit, if you have a large number of jobs and
> > > bookings the rescheduling routine seems to clear some things
up
> > and
> > > the reports tend to be more accurate. Generally, if possible,
> keep
> > > it as simple as possible. Don't try and tie everything down.
Use
> > the
> > > testing to identify the exact issues, is it the job
> configuration,
> > > workcenter configurations etc.
> > > I hope this helps.
> > > --- In vantage@yahoogroups.com, "Lepley, Scott A." <sal@>
wrote:
> > > > What version are you running, Nam?
> > > > I am considering this as well. Unfortunately, at this
point,
> we
> > > only use
> > > > the job scheduling function to facilitate the calculations
> > related
> > > to
> > > > time-phase material requirements and purchase suggestions.
We
> > are
> > > not using
> > > > Scheduling to plan/monitor/adjust production capacity for
two
> > > basic reasons.
> > > > Firstly and primarily, many of our jobs are not sufficiently
> > > planned
> > > > operationally to be conducive to scheduling. Secondly,
nobody
> > > seems
> > > > interested in using the scheduling boards. I'm thinking
that
> > > perhaps we
> > > > don't have anything to lose by running GFS, but I've been
> > > cautioned in the
> > > > past about doing this. I was advised just to use Job
> Scheduling
> > > and then
> > > > adjust the production schedule using the scheduling boards,
> but
> > > that brings
> > > > me right back to my previous statement. Anyway, I would be
> > > particularly
> > > > interested in hearing about pitfalls that others have
> > encountered
> > > with GFS.
> > > > Regards,
> > > > Scott Lepley
> > > > Systems Administrator
> > > > Mauell Corporation
> > > > Phone: 717-432-8686, ext. 14
> > > > Fax: 717-432-8688
> > > > Email: sal@
> > > > Vantage version: 6.10.532
> > > > From: progress92000 [mailto:nvong@]
> > > > Sent: Tuesday, March 14, 2006 8:52 AM
> > > > Subject: [Vantage] Global Finite Scheduling
> > > > Hi Everyone,
> > > > I am planning to use Global Finite Scheduling to help
avoiding
> > > over
> > > > capacity.
> > > > Anyone has used this Global Finite Scheduling? any impact or
> > must
> > > be
> > > > aware of. What is the best procedures to implement this GFS?
> > > > Would like to have yout input.
> > > > Thanks,
> > > > Nam
You
> must
> access. )
> Builder
> > Yahoo! Groups Links
must
access. )
Builder
> Yahoo! Groups Links
Message: 3
Date: Wed, 15 Mar 2006 11:52:39 -0600
Subject: RE: Syntax Error 7587
Ben,
Additional follow-up I found this a few days ago on the Progress Website
it might be helpful for you, again it was not what caused my problem
* Getting error (7587) when updating a record from an Application
via ODBC.
* Syntax error (7587).
* ERROR[42000][MERANT][ODBC PROGRESS driver][PROGRESS] syntax
error (7587).
Cause:
The name of the table owner as well as the name of the actual table are
being specified within the SET clause in the UPDATE command. There is no
need to specify that information. e.g.:
UPDATE pub.Customer SET pub.Customer.name = 'Progress Software' WHERE
pub.Customer.CustNum = 1
Fixes:
Take the name of the table owner as well as the name of the actual table
out of the SET clause within the UPDATE command. e.g.:
UPDATE pub.Customer SET name = 'Progress Software' WHERE
Dan Shallbetter
States Electric Mfg.
Of Dan Shallbetter
Sent: Wednesday, March 15, 2006 11:17 AM
Ben,
What is the full error message?
I have been seeing failed to open row set details:42000 Merant odbc
Progress driver [Progress] syntax error 7587. I too applied the
uncommitted suggestion without any luck.
My situation is I have both Crystal 8.5 and Crystal 9.0 on my client. I
recall having to roll back some dll's after installing 9.0 in order get
canned Vantage reports to work. I also have Crystal 9.0 installed on my
server to support eportal lite, a report application server (a watered
down Crystal Enterprise application). Opening the same report on my
server does not produce the error. both DSN are configured the same I
concluded that it must be a dll issue on my client.
Hope this helps.
Dan Shallbetter
Of Ben Belzer
Sent: Wednesday, March 15, 2006 10:37 AM
I switched it over to read uncommitted and no luck. Syntax Error 7587.
Of Kennedy, Jim
Open your ODBC Data Source Administrator, select the Vantage ODBC driver
(Most probably identified as MERANT 3.60 32-BIT Progress SQL92 if you're
Uncommitted"
I know certain users like to use various size fetch arrays, but you'll
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@...
Of Ben Belzer
Thanks!
Of Kennedy, Jim
The PartTran is almost always being accessed by a number of programs.
I found that as long as I'm in the "read uncommitted" mode with my ODBC
it won't fail me.
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@...
Of RICH WAGNER
I am trying to access the PartTran table using ODBC and I am getting a
syntax error 7587.
Has anyone ever encountered this? This is the only table that gives me
this error.
Thanks!
Ben Belzer
IT Manager
800.234.5613.W
310.323.1255.F
Message: 4
Date: Wed, 15 Mar 2006 17:59:45 -0000
Subject: Vntg 6.0 Help and Content Filter
We have the content filter set up in Windows XP pointing to a
noaccess.rat (ratings) file to keep some people from accessing the
Internet. When these user try to use Vantage Help, they constantly
prompted by the filter for the password to access the site. They can
click Cancel out of the prompt and Help still works but it is
annoying.
Is there anyway to stop Help from looking like it is accessing the
Internet? Or is there some general, catch-all, exception I can put in
their Approved Sites list?
Thanks!
Erik Smalley
IT Manager
MEI
Message: 5
Date: Wed, 15 Mar 2006 12:53:21 -0500
Subject: RE: Server Specs
If you plan on implementing after imaging, you will want three mirrored
drives.
Otherwise you can get away with two.
One array for your OS and VM file, the other for your Progress Bi files.
Of Mitchell Kirby
Sent: Wednesday, March 15, 2006 11:34 AM
Subject: [Vantage] Server Specs
My HP server is no longer supported under maintenance by HP. We were
considering going to 8.0 some time next year so now I am in the hunt for
a
new server. What are the real specs for 15 users, 8 data collection
users
and a 1.4 gig database? We also have CorVu and advanced shipping on
this
server.
Your comments would be appreciated.
Sincerely,
Mitchell Kirby
Riten Industries, Inc.
< http://www.riten.com/> www.riten.com
740-333-8719 Direct
800-338-0027 Sales
800-338-0717 FAX
< http://groups.yahoo.com/group/vantage/files/>
SPONSORED LINKS
Manufacturing software
< http://groups.yahoo.com/gads?t=ms
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage
< http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service < http://docs.yahoo.com/info/terms/> .
Message: 6
Date: Wed, 15 Mar 2006 10:09:50 -0800
Subject: indirect labor codes
Can someone clarify for me how the indirect labor entered through the
labor
entry function works if one does not have or use the payroll module? I
am
hoping that it allow the aggregation of all this "indirect time" (ie.
repair/maintenance/cleaning/etc) into a GL account so that such amounts
can
be tracked and processed as OH or maintenance costs? In the
alternative,
can anyone provide a better method through Vantage of tracking such
miscellaneous time that is not attributable to a "job".
Thanks for any help.
Kyle Chin
Optoplex Corporation
Internal Virus Database is out-of-date.
Checked by AVG Free Edition.
Version: 7.1.362 / Virus Database: 267.13.10/189 - Release Date:
11/30/2005
Message: 7
Date: Wed, 15 Mar 2006 11:03:21 -0800
Steps to reproduce my error:
Open Excel
Click Import External Data / New Database Query
Choose Vantage
Enter Password
Choose the PartTran table and the TranType field
Click next a few times until "View Data or edit Query in Microsoft
Query"
Click finish
SYNTAX ERROR 7587
Of Dan Shallbetter
Sent: Wednesday, March 15, 2006 9:17 AM
Ben,
Hope this helps.
Dan Shallbetter
Of Ben Belzer
Of Kennedy, Jim
Uncommitted"
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@...
Of Ben Belzer
Thanks!
Of Kennedy, Jim
it won't fail me.
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@...
Of RICH WAGNER
syntax error 7587.
this error.
Thanks!
Ben Belzer
IT Manager
800.234.5613.W
310.323.1255.F
Yahoo! Groups Links
Message: 8
Date: Wed, 15 Mar 2006 11:08:11 -0800
Subject: Inventory Average-Cost
I have uncovered something potentially very dangerous. The average cost
can be way off if you delete a receipt.
Steps to reproduce:
Had 100 pieces @ 1.00 on hand.
Placed PO for 1000 pcs at $2.00.
Received 1,000,000 pcs on accident sending the average cost to 1.999
Deleted the receipt bringing on-hand qty back to 100 yet the average is
still 1.999.
Can someone shed light on this? It could mean that average costing is
not the way to go...
Ben
Ben Belzer
IT Manager
800.234.5613.W
310.323.1255.F
Message: 9
Date: Wed, 15 Mar 2006 14:21:44 -0500
Subject: RE: Inventory Average-Cost
Can't Delete a receiver... When we have errors on the receiver I just
have to fix the average cost.
Of Ben Belzer
Sent: Wednesday, March 15, 2006 2:08 PM
Subject: [Vantage] Inventory Average-Cost
Steps to reproduce:
still 1.999.
Ben
Ben Belzer
IT Manager
800.234.5613.W
310.323.1255.F
Yahoo! Groups Links
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
Message: 10
Date: Wed, 15 Mar 2006 14:26:35 -0500
Okay. I found that using Microsoft query, the only way I could
successfully query the PartTran table was to open a new query, edit it
in Microsoft query, turn of the "Auto Query" function, add the PartTran
table, then select the columns you want to retrieve and add specific
criteria to limit the dataset that's returned.
For example (I just did this now to prove it out...)
SELECT DISTINCT PartTran_0.TranType, PartTran_0.PartNum,
PartTran_0.TranQty, PartTran_0.PartDescription
FROM PUB.PartTran PartTran_0
WHERE (PartTran_0.TranDate Between ? And ?) AND (PartTran_0.TranType
Like ?)
Then I input "3/1/06 & 3/14/06" for the date range and "adj-qty" for the
transaction type.
This is the only way I know to get around that error.
Good luck!
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@...
Of Ben Belzer
Sent: Wednesday, March 15, 2006 2:03 PM
Open Excel
Choose Vantage
Enter Password
Query"
Click finish
SYNTAX ERROR 7587
Of Dan Shallbetter
Ben,
Hope this helps.
Dan Shallbetter
Of Ben Belzer
Of Kennedy, Jim
Uncommitted"
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@...
Of Ben Belzer
Thanks!
Of Kennedy, Jim
it won't fail me.
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@...
Of RICH WAGNER
syntax error 7587.
this error.
Thanks!
Ben Belzer
IT Manager
800.234.5613.W
310.323.1255.F
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
This Email has been scanned for all potential viruses.
SPONSORED LINKS
Manufacturing
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software
Membership
database software Database
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage
software
Pda
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database
software Database
management software Database
marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage
<http://groups.yahoo.com/group/vantage> " on the web.
Service <http://docs.yahoo.com/info/terms/> .
_____
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
