goto: vantage-subscribe@yahoogroups.com and try again. Don't know why they
didn't like you, might be the answers you gave ??? You must belong to Yahoo
first to join groups also.
> -----Original Message-----
> From: vantage@yahoogroups.com [SMTP:vantage@yahoogroups.com]
> Sent: Friday, July 25, 2003 2:24 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Digest Number 2470
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> There are 6 messages in this issue.
> Topics in this digest:
> 1. RE: Convmap.cp error
> From: "Administrator" <administrator@...>
> 2. Export Calculations / Business Activity Query 6.0
> From: "Don Kollmann" <donk@...>
> 3. Version 5.2 Scheduling Screen tree collapsing
> From: Carol Engen <cengen@...>
> 4. Human Resources Software
> From: "Sherer, Rhonda" <rhonda@...>
> 5. BOM importing
> From: "Reilly, Rhonda" <rreilly@...>
> 6. OT - Software to assess network for compliance to piracy,
> hardware status, software status, etc.
> From: "Rick Gors" <rgors@...>
> ________________________________________________________________________
> Message: 1
> Date: Thu, 24 Jul 2003 12:17:09 -0700
> Subject: RE: Convmap.cp error
> Take a look at the following.....
> PROBLEM: Opening custom report links in Vantage generates the error:
> Unable
> to open convmap.
> XA500
> XA510
> XA520
> RESOLUTION: Vantage 5.00 and higher no longer uses the Vantage.ini to
> connect to report builder.
> The report builder.vtg "other parameters" line no longer uses 'Basekey
> ini'. It now uses the Progress.ini by default.
> Report builder.vtg example:
> [Vantage Startup]
> Executable=V:\Progress\bin\prorb32.exe
> Database=V:\Vantage\db\vantage
> IniFile=V:\Vantage\Vantage.ini
> ParameterFile=V:\Vantage\db\Vantage.pf
> ConnectOptions=-N TCP -H mntech -S epic50
> TempDirectory=C:\Vntg50
> StartupProcedure=
> OtherParameters=
> --> NOTE: the 'OtherParameters=' line is now blank
> Apparently this causes no problem with the database engine because it uses
> the registry. You will need to edit the \Progress\Bin\progress.ini to
> reference the mapped drive path instead of the physical drive path.
> After editing the startup section it should look something like this:
> Progress.ini
> [Startup]
> V6Display=no
> ;ImmediateDisplay=yes
> ;MultitaskingInterval=100
> DefaultFont=MS Sans Serif, size=8
> DefaultFixedFont=Courier New, size=8
> DLC=V:\progress
> Use-3D-Size=Yes
> PROBUILD=V:\progress\PROBUILD
> PROPATH=.,V:\progress\gui,V:\progress,V:\progress\bin,V:\progress\PROBUILD
> \E
> UCAPP\EUC.PL,V:\progress\PROBUILD\EUCAPP
> UseSourceEditor=yes
> ;EditorConfigPath=V:\prowork\proedit
> Where V is a mapped drive.
> Pay special attention to the DLC path, and be certain that it says
> V:\progress, NOT V:\epic50\progress.
> OTHER POSSIBILITES:
> Check the Environment Variables in the System Control Panel on the problem
> machine. If there is a reference to a DLC, make certain it points to the
> correct mapped driver letter.
> Check the REGISTRY for any references to DLC. These need to be pointing to
> the correct mapped drive for Vantage.
> XA500
> XA510
> XA520
> From: Jasper Recto [mailto:jrecto@...]
> Sent: Thursday, July 24, 2003 12:09 PM
> To: Vantage Groups (E-mail)
> Subject: [Vantage] Convmap.cp error
> Hello all,
> I have a user who get this error when ever he tries to print/view a custom
> reports. He is able to print any of the can reports that came with
> Vantage.
> Unable to open convmap file '\convmap.cp'
> It only happens on his computer. Any ideas?
> Thanks,
> Jasper
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> <http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=170500
> 7183:HM/A=1663535/R=0/SIG=11ps6rfef/*http://www.ediets.com/start.cfm?code=
> 30504&media=atkins> click here
> <http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupm
> ail/S=:HM/A=1663535/rand=485529408>
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
> Message: 2
> Date: Thu, 24 Jul 2003 15:56:17 -0500
> Subject: Export Calculations / Business Activity Query 6.0
> Hello Group:
> I am trying to get a summary total to display of invoice amounts by
> customer.
> Is this possible to do in the export utility?
> If so what is the proper syntax to get this to display.
> Thank you
> Don Kollmann
> Heartland EPS
> donk@...
> Message: 3
> Date: Thu, 24 Jul 2003 16:00:57 -0500
> Subject: Version 5.2 Scheduling Screen tree collapsing
> When going into Enhanced Scheduling, if I make a what-if change to the
> schedule, the scheduling tree (by operation) collapses to show just one
> line
> for the job. I need to double click on the job to get the scheduling
> screen
> to appear in tree-format. What can I do to keep it always in a tree
> format?
> Am I missing a screen customizing option?
> (In version 5.2.313)
> Also, does anyone have the problem of the Scheduling board dropping behind
> all other open menus?
> Thank you,
> Carol Engen
> Controller
> Winona Lighting
> Phone: 507-454-5113, Ext. 314
> Fax: 507-454-4806
> e-mail: cengen@... <mailto:cengen@...>
> Message: 4
> Date: Thu, 24 Jul 2003 16:22:46 -0500
> Subject: Human Resources Software
> Hi
> Ceasar Developement: 860-667-4774 We have their product too.
> From: Doug Oswald [mailto:dougo@...]
> Sent: Thursday, July 24, 2003 11:37 AM
> Subject: [Vantage] [OT] Human Resources Software
> We are looking to purchase an HRIS system. We are currently using
> Excel to do most of our employees' information. We have grown to a
> point where this is no longer working. We need to be able to track
> everything from insurance coverage to injuries to salaries.
> What package is a good value?
> Message: 5
> Date: Thu, 24 Jul 2003 17:01:16 -0500
> Subject: BOM importing
> I was checking out the importing of BOM's from a text file in 5.2. I read
> that if the part number is not in the master file it will created it. I
> get
> to the import and get an error message "a valid Warehouse is required" and
> it doesn't create the part to import into the BOM. Anyone know what I
> need
> to do to get this done.
> Thanks
> Rhonda Reilly
> Information Resource Manager
> American Aero / Titan
> 985.893.1818
> 985.893.1879 fax
> Message: 6
> Date: Fri, 25 Jul 2003 02:55:40 -0400
> Subject: OT - Software to assess network for compliance to piracy,
> A friend needs software to run on their network to log and access what is
> connected and loaded, etc. They discharged the IT person for running a
> gamer web site on the server but did little else.
> Any suggestions would be welcome.
> TIA
> Rick Gors
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
