Deployment Error
Has anyone ever run into an error when deploying an app server that says access to the path is denied? It is driving me absolutely nuts!! Everything still works, but the Admin Console says that the current deployment is not installed.
Seems your network path missing user rights to write so check and assign user rights
Regards,
Surendra Pal
Sorry, should have said that the account that is being used is an admin. Full rights to the whole server.
I would specifically check the Share permissions. Just because the user is an admin does not mean at the share level they have full permission.
Thanks Dan.
I pulled up my Task Agent server and compared the share settings to my Application server. The folder shares were not set up the same at different folder levels. Once I made the App server the same it worked.
Appreciate the help.
