Correct in Vantage 8.03 you can just make the change under process
calling maintenance.
Of Jose Gomez
Sent: Friday, May 13, 2011 3:50 PM
Subject: Re: [Vantage] Deploying Customizations in Vantage 8.03
Not sure about Vantage 8 but in 9 you can change Process Calling
Maintenance and Context Menu Maintenance which makes it default for
almost everything if not everything.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.linkedin.com/in/josecgomez>
<http://www.facebook.com/josegomez>
<http://www.google.com/profiles/jose.gomez>
<http://www.twitter.com/joc85>
On Fri, May 13, 2011 at 3:58 PM, Brian W. Spolarich <
bspolarich@...> wrote:
M-B Companies Confidentiality Notice:
This message is being sent by M-B Companies. It is intended exclusively for
the individuals and entities to which it is addressed. This communication,
including any attachments, may contain information that is proprietary,
privileged and confidential if you are not the named addressee; you are not
authorized to read,print,retain copy or disseminate this message or any part
of it.If you have received this message in error, please notify the sender
immediately by email.
Of Jose Gomez
*Jose C Gomez*
*Software Engineer*
E: jose@...
>[Non-text portions of this message have been removed]
> Customizations are deployed on a per-menu-item basis. If you want to
> change them all, you'll have to apply the customization to each menu
> item individually.
> -bws
> Behalf Of Richard
> Sent: Friday, May 13, 2011 3:53 PM
> Subject: [Vantage] Deploying Customizations in Vantage 8.03
> Hi Vatagarians,
> In Vantage 8.03 we created a customization of the part tracker and
> want to deploy it. The part tracker appears 9 separate times in
> different sub-menus. Does the customized tracker have to be deployed
> at each instance or does deploying it in one also replace the original
> tracker throughout the menu? Is it optional so that the new form can
> be deployed either throughout the menu or instance by instance?
> Thanks in advance for any input.
> Rick
