Hi All,
I am trying to deploy a customization that we have for Order Entry to
EWA.
Epicor hasn't received our check yet for maintenance so I can't call
support or get to answer book so I was wondering if someone could help
me with how to do this.
I went Customization/Personalization Maintenance, selected my
customization and then went to Actions -> Generate Web Form
It pauses for a second and then throws an error, that I've included
below.
After I click ok, a window flashes for a second and then closes.
There is no "complete" dialog box so I don't know if it's done but there
is no customization in EWA.
The customization is written in C#.
Any ideas? Is there another step to deploy the customization?
Here is my error:
Error Detail
Exception has been thrown by the target of an invocation.
Stack Trace
at System.RuntimeMethodHandle._InvokeMethodFast(Object target,
Object[] arguments, SignatureStruct& sig, MethodAttributes
methodAttributes, RuntimeTypeHandle typeOwner)
at System.RuntimeMethodHandle.InvokeMethodFast(Object target,
Object[] arguments, Signature sig, MethodAttributes methodAttributes,
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj,
BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo
culture, Boolean skipVisibilityChecks)
culture)
at Epicor.Mfg.UI.FrameWork.AssemblyLoader.TranslateCustomCode(String
vdir, String assemblySubFolder, String uiappFormName)
Inner Exception
Index was out of range. Must be non-negative and less than the size of
the collection.
Parameter name: index
Inner Stack Trace
at
System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument
argument, ExceptionResource resource)
at System.ThrowHelper.ThrowArgumentOutOfRangeException()
at System.Collections.Generic.List`1.get_Item(Int32 index)
at DDW.Parser.ParseIndexer(IType type, QualifiedIdentifierExpression
interfaceType)
at DDW.Parser.ParseClassMember()
at DDW.Parser.ParseClass()
at DDW.Parser.ParseNamespaceOrTypes()
at DDW.Parser.Parse(TokenCollection tokens, List`1 strings)
at Epicor.Mfg.UI.WinToWeb.TranslationEngine.parseFile(StreamReader
sr, String fileName, RulesManager rules)
at
Epicor.Mfg.UI.WinToWeb.TranslationEngine.TranslateCustomCode(ILaunch
Sender)
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
