Dependent search in BAQ Report Filters
In some stock Epicor screens (ie. Order/PO entry), when you search for line numbers, the search results are dependent on the Order/PO that was selected previously.
I was wondering if this is possible to do within the filters for a BAQ report. For example, I have Part, Revision, and lot number as filters. However I only want to see Revision and Lot numbers based on the Part number I select first.
I don’t have the answer. I am thinking you might be able to make a wonky customization that intercepts the search method and does something special like add a row filter based on the previous selection. But that doesn’t sound ideal. Maybe there’s a way in the RDD? That would be nice. But I’m not sure.
