At 04:51 PM 2/20/2003 -0500, you wrote:
still show up just fine as a username stamp in PartTran and elsewhere even
after deletion.
Only caveat -- Vantage fails to delete some of the associated items from
other tables. The Favorites (FavFolder & FavItems) and Security tables
come to mind; there may be others. There should be triggers or program
logic to clean these up. Someone wanna' submit a request?
There is one related problem I've encountered. You can not delete a user
defined menu item (like you might create for report builder reports) if a
user has a favorites item pointing to it. You can use report builder to
determine the culprit. But if it is a deleted user, you have to re-add
them, delete the favorites, and re-delete the user to get rid of the menu item.
-Wayne Cox
Twenty Three - Information Technology Consulting
828-685-2338
>We have a number of Users in Vantage that have been disabled. Is it safeI always deleted them when people parted ways with the company. They will
>to delete these users?
after deletion.
-Wayne Cox
828-685-2338
