Delete User - Referenced by Requisition Action
Check Material Management>Purchase Management>Setup>Requisition Actions. One of the actions most likely has the user referenced as an authorized user. Remove them from the Selected Users list and you should be able to delete the user (if that's the only reference). Other areas that may stop you from deleting a user are buyers, workforce, and person/contact. Once all references are deleted, users can be deleted.
Sue
---In vantage@yahoogroups.com, <cchang@...> wrote :
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 filtered #ygrps-yiv-1890900122ygrps-yiv-2023662808 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;} #ygrps-yiv-1890900122 filtered #ygrps-yiv-1890900122ygrps-yiv-2023662808 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;} #ygrps-yiv-1890900122 filtered #ygrps-yiv-1890900122ygrps-yiv-2023662808 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} #ygrps-yiv-1890900122 filtered #ygrps-yiv-1890900122ygrps-yiv-2023662808 {font-family:Verdana;panose-1:2 11 6 4 3 5 4 4 2 4;} #ygrps-yiv-1890900122 filtered #ygrps-yiv-1890900122ygrps-yiv-2023662808 {font-family:Consolas;panose-1:2 11 6 9 2 2 4 3 2 4;} #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808MsoNormal, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808MsoNormal, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman", "serif";} #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 a:link, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 span.ygrps-yiv-1890900122ygrps-yiv-2023662808MsoHyperlink { color:blue;text-decoration:underline;} #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 a:visited, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 span.ygrps-yiv-1890900122ygrps-yiv-2023662808MsoHyperlinkFollowed { color:purple;text-decoration:underline;} #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p {
margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 code
font-family:“Courier New”;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 pre
margin:0in;margin-bottom:.0001pt;font-size:10.0pt;font-family:“Courier New”;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 tt
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 span.ygrps-yiv-1890900122ygrps-yiv-2023662808cat
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 span.ygrps-yiv-1890900122ygrps-yiv-2023662808ct
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 span.ygrps-yiv-1890900122ygrps-yiv-2023662808HTMLPreformattedChar
font-family:Consolas;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808attach, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808attach, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808attach
margin-right:0in;margin-left:0in;font-size:9.0pt;font-family:“Arial”, “sans-serif”;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808bold, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808bold, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808bold
margin-right:0in;margin-left:0in;font-size:10.0pt;font-family:“Arial”, “sans-serif”;font-weight:bold;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808green, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808green, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808green
margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;color:#628C2A;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808replbq, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808replbq, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808replbq
margin:3.0pt;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808ad, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808ad, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808ad
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808underline, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808underline, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808underline
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 span.ygrps-yiv-1890900122ygrps-yiv-2023662808yshortcuts
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808ad1, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808ad1, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808ad1
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808ad2, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808ad2, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808ad2
margin-right:0in;margin-bottom:7.5pt;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 p.ygrps-yiv-1890900122ygrps-yiv-2023662808underline1, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 li.ygrps-yiv-1890900122ygrps-yiv-2023662808underline1, #ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808underline1
margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:“Times New Roman”, “serif”;text-decoration:underline;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 span.ygrps-yiv-1890900122ygrps-yiv-2023662808yshortcuts1
font-family:“Verdana”, “sans-serif”;font-weight:bold;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 span.ygrps-yiv-1890900122ygrps-yiv-2023662808yshortcuts2
font-family:“Verdana”, “sans-serif”;font-weight:normal;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 span.ygrps-yiv-1890900122ygrps-yiv-2023662808EmailStyle36
font-family:“Calibri”, “sans-serif”;color:#1F497D;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 .ygrps-yiv-1890900122ygrps-yiv-2023662808MsoChpDefault
font-size:10.0pt;}
margin:1.0in 1.0in 1.0in 1.0in;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 div.ygrps-yiv-1890900122ygrps-yiv-2023662808WordSection1
font-family:Symbol;}
font-family:Wingdings;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 ol
{margin-bottom:0in;}
#ygrps-yiv-1890900122 #ygrps-yiv-1890900122ygrps-yiv-2023662808 ul
We are trying to delete a User Account but an error indicates that we cannot delete it because it is ‘Referenced by at least one Requisition Action.’  Where do we look to complete or delete this Requisition Action?
<!-- #ygrps-yiv-72392834 _filtered #ygrps-yiv-72392834 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-72392834 {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #ygrps-yiv-72392834 {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #ygrps-yiv-72392834 {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #ygrps-yiv-72392834 {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4;} #ygrps-yiv-72392834 #ygrps-yiv-72392834 p.ygrps-yiv-72392834MsoNormal, #ygrps-yiv-72392834 li.ygrps-yiv-72392834MsoNormal, #ygrps-yiv-72392834 div.ygrps-yiv-72392834MsoNormal {margin:0in; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman", "serif";} #ygrps-yiv-72392834 a:link, #ygrps-yiv-72392834 span.ygrps-yiv-72392834MsoHyperlink { color:blue; text-decoration:underline;} #ygrps-yiv-72392834 a:visited, #ygrps-yiv-72392834 span.ygrps-yiv-72392834MsoHyperlinkFollowed { color:purple; text-decoration:underline;} #ygrps-yiv-72392834 p {
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-72392834 code
#ygrps-yiv-72392834 pre
margin:0in;
font-size:10.0pt;
#ygrps-yiv-72392834 tt
#ygrps-yiv-72392834 span.ygrps-yiv-72392834cat
#ygrps-yiv-72392834 span.ygrps-yiv-72392834ct
#ygrps-yiv-72392834 span.ygrps-yiv-72392834HTMLPreformattedChar
#ygrps-yiv-72392834 p.ygrps-yiv-72392834attach, #ygrps-yiv-72392834 li.ygrps-yiv-72392834attach, #ygrps-yiv-72392834 div.ygrps-yiv-72392834attach
margin-right:0in;
margin-left:0in;
font-size:9.0pt;
#ygrps-yiv-72392834 p.ygrps-yiv-72392834bold, #ygrps-yiv-72392834 li.ygrps-yiv-72392834bold, #ygrps-yiv-72392834 div.ygrps-yiv-72392834bold
margin-right:0in;
margin-left:0in;
font-size:10.0pt;
font-weight:bold;}
#ygrps-yiv-72392834 p.ygrps-yiv-72392834green, #ygrps-yiv-72392834 li.ygrps-yiv-72392834green, #ygrps-yiv-72392834 div.ygrps-yiv-72392834green
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
color:#628C2A;}
#ygrps-yiv-72392834 p.ygrps-yiv-72392834replbq, #ygrps-yiv-72392834 li.ygrps-yiv-72392834replbq, #ygrps-yiv-72392834 div.ygrps-yiv-72392834replbq
margin:3.0pt;
font-size:12.0pt;
#ygrps-yiv-72392834 p.ygrps-yiv-72392834ad, #ygrps-yiv-72392834 li.ygrps-yiv-72392834ad, #ygrps-yiv-72392834 div.ygrps-yiv-72392834ad
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-72392834 p.ygrps-yiv-72392834underline, #ygrps-yiv-72392834 li.ygrps-yiv-72392834underline, #ygrps-yiv-72392834 div.ygrps-yiv-72392834underline
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-72392834 span.ygrps-yiv-72392834yshortcuts
#ygrps-yiv-72392834 p.ygrps-yiv-72392834ad1, #ygrps-yiv-72392834 li.ygrps-yiv-72392834ad1, #ygrps-yiv-72392834 div.ygrps-yiv-72392834ad1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-72392834 p.ygrps-yiv-72392834ad2, #ygrps-yiv-72392834 li.ygrps-yiv-72392834ad2, #ygrps-yiv-72392834 div.ygrps-yiv-72392834ad2
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-72392834 p.ygrps-yiv-72392834underline1, #ygrps-yiv-72392834 li.ygrps-yiv-72392834underline1, #ygrps-yiv-72392834 div.ygrps-yiv-72392834underline1
margin-right:0in;
margin-left:0in;
font-size:12.0pt;
#ygrps-yiv-72392834 span.ygrps-yiv-72392834yshortcuts1
font-weight:bold;}
#ygrps-yiv-72392834 span.ygrps-yiv-72392834yshortcuts2
#ygrps-yiv-72392834 span.ygrps-yiv-72392834EmailStyle36
color:#1F497D;}
#ygrps-yiv-72392834 .ygrps-yiv-72392834MsoChpDefault
font-size:10.0pt;}
#ygrps-yiv-72392834 div.ygrps-yiv-72392834WordSection1
#ygrps-yiv-72392834
#ygrps-yiv-72392834 ol
#ygrps-yiv-72392834 ul
From my experience it seems if you do anything with a user it is not possible to delete.
If you want to check against the database directly where the User ID has been used, you can use this stored procedure. I was in the same position looking for a user that was in our workforce as a salesperson that we've never heard of, and couldn't remove because it was referenced somewhere. Someone provided this to me, and it works a dream =).
Create the stored procedure and then use it by entering EXEC [dbo].[SearchAllTables] 'UserID'
Cheers!
USE [E10]
go
SET ansi_nulls ON
go
SET quoted_identifier ON
go
CREATE PROC [dbo].[Searchalltables] (@SearchStr NVARCHAR(100))
AS
BEGIN
CREATE TABLE #results
columnname NVARCHAR(370),
columnvalue NVARCHAR(3630)
  SET nocount ON
  DECLARE @TableName  NVARCHAR(256),
          @ColumnName NVARCHAR(128),
          @SearchStr2 NVARCHAR(110)
  SET @TableName = &#39;&#39;
  SET @SearchStr2 = Quotename(&#39;%&#39; + @SearchStr + &#39;%&#39;, &#39;&#39;&#39;&#39;)
  WHILE @TableName IS NOT NULL
    BEGIN
        SET @ColumnName = &#39;&#39;
        SET @TableName = (SELECT Min(Quotename(table_schema) + &#39;.&#39;
                                     + Quotename(table_name))
                          FROM   information_schema.tables
                          WHERE  table_type = &#39;BASE TABLE&#39;
                                 AND Quotename(table_schema) + &#39;.&#39;
                                     + Quotename(table_name) &gt; @TableName
                                 AND Objectproperty(Object_id(Quotename(
                                                              table_schema
                                                              &#39;.&#39;
                                                              + Quotename(
                                                              table_name
                                     &#39;IsMSShipped&#39;) =
                                     0)
        WHILE ( @TableName IS NOT NULL )
              AND ( @ColumnName IS NOT NULL )
          BEGIN
              SET @ColumnName = (SELECT Min(Quotename(column_name))
                                 FROM   information_schema.columns
                                 WHERE  table_schema = Parsename(@TableName,
                                                       2
                                        AND table_name =
                                            1)
                                        AND data_type IN ( &#39;char&#39;, &#39;varchar&#39;
                                                           &#39;nchar&#39;,
                                                           &#39;nvarchar&#39; )
                                        AND Quotename(column_name) &gt;
                                            @ColumnName)
              IF @ColumnName IS NOT NULL
                BEGIN
                    INSERT INTO #results
                    EXEC ( &#39;SELECT &#39;&#39;&#39; + @TableName + &#39;.&#39; + @ColumnName +
                    &#39;&#39;&#39;, LEFT(&#39; +
                    @ColumnName
                    + &#39;, 3630)
FROM ' + @TableName + ' (NOLOCK) ' + ' WHERE ' +
@ColumnName
' LIKE '
@SearchStr2 )
END
END
END
  SELECT columnname,
         columnvalue
  FROM   #results
END
