Hi Everybody, how can i delete UD100A record from Custom Code?
i tried with DeleteByID but isn’t working
Regards and Thanks
Regards and Thanks
Have you already tried setting the .RowMod = “D”;
This post is for removing an OrderRel but thinking it could be applied to UD100A
or at least it might give you some ideas…
DeleteByID is for UD100 if I recall in order to delete the children you Get UD100 and then you iterate through the children and mark them as RowMod “D” then you call Update.
Assuming your doing it in a Customization.
ud100Adapter.UD100Data.UD100A.Rows
I will try, in a few minutes i let you know thre results
Hi again, i tried this:
foreach(DataRow dr in adapterUD101.UD101Data.UD101A.Rows)
if(dr["ChildKey1"].ToString() == childKey)
MessageBox.Show(""+childKey);
adapterUD101.UD101Data.UD101A.Rows[i].BeginEdit();
adapterUD101.UD101Data.UD101A.Rows[i]["RowMod"] ="D";
adapterUD101.UD101Data.UD101A.Rows[i].EndEdit();
adapterUD101.Update();
i++;
but doesn’t work, did i forget something?
// Try This First
dr.BeginEdit();
dr["RowMod"] = "D";
dr.EndEdit();
// Second Try This
// I think this is the way I usually have it for a regular UD table atleast not sure if same works with a child
adapterUD101.Delete(dr);
The second way works
I only added a “break” on the loop
here the code:
if(dr[“ChildKey1”].ToString() == childKey)
break;
thank you very much for your help
