That is what I ended up doing – Thank you
Sent: Tuesday, April 26, 2016 12:15 PM
To: Vantage
Subject: Re: [Vantage] Delete UD table from Customization
The easiest way would be to remove all the code they added for you.... OR if this is the only code you could just start a new Code Layer and save a new customization
(will keep the UI but remove all extraneous code)
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Tue, Apr 26, 2016 at 2:51 PM, cathy@... [vantage] <vantage@yahoogroups.com> wrote:
I added a UD table in Customizations > Tools > Wizards > Customization Wizard > Add User Define Table as Child.
I want to delete this table from RMADtl because it is causing problems.
When I take the same path in Step 1 of 2 - it states "Retrieve/Add/Edit/Delete UD table from your UI".
For me, it is not intuitive and I don't know how to retrieve to edit or delete.
Does anyone have any instructions?
