Decision Wizard
Is there a way you can create a PO for a list of parts in the RFQ Decision Wizard instead of doing it line buy line? Seems a bit redundant. There should be a way to combine several parts on one PO if it’s the same supplier. Is the only way using PO Suggestions? Or am I missing something? I just recently started working with RFQ Entry, so I’m a bit new to this area in Epicor.
