Debugging in Epicor
How do you debug in Epicor? Is there some sort of writeline or debug.print? I could use?
Use Visual Studio (Look in the manual it tells you how, Ice Customization Guide , or Help F1 search for Visual Studio)
I use visual studio already with your plugin. I would like a way to print out text rather then doing messageboxes tho.
No i mean use visual studio for debugging again check the help its all there
You can place breaks in your code, and much more.
