Hi
In customizations you can choose Visual Studio to debug the customization code and step through the code lines. How can i do that with BPMs & Functions?
Hi
Yeah, this is a fun one.
I’m not aware of a way to add breakpoints and step through BPMs/Functions (would love to know how to do this if it’s possible!)
A lot of people swear by the server logs but I found that fiddly and opted to write a function to handle my debug. Simplified, it looks something like this:
// Epicor Function - CommonFunctions.LogToFile
// Request Parameters:
// sFileLocation System.String - network location of log file
// sComment System.String - text to add to file
// bDateStamp System.Bool - if true add line including current date and time
// bSeperator String.Bool - if true add a separator beneath comment line
// Response Parameters
// nil
// using System.IO;
// add individual string to file
Action<string>WriteLine = (s) =>
StreamWriter obj = new StreamWriter(sFileLocation, File.Exists(sFileLocation));
obj.WriteLine(s);
obj.Close();
obj = null;
Action<string>WriteLog = (s) =>
if (bDateStamp) {WriteLine("Log Entry: " + $"{DateTime.Now.ToLongTimeString()} {DateTime.Now.ToLongDateString()}");}
WriteLine(s);
if (bSeperator) {WriteLine("-------------------------------");}
WriteLog(sComment);
I’ve got a few common functions that I use universally. I added them all to a function library (in this example I’ll call it “CommonFunctions” and I include that library in other projects.
To call it from another function library:
if (bDebugMode){this.EfxLib.CommonFunctions.LogToFile(sDebugFile, "Whatever you want to see in your debug", bAddTime, bSep);}
Just remember your debug file is written from the server so you need a network path for the file, not a locally mapped drive letter.
I’m keen to see what others do, too. Debugging plays a big part of any dev’s repertoire and I’m always looking for a better way to handle this.
I found some info online that might be of interest to you here
How to Debug a Epicor BPM in Visual Studio (youtube.com)
Little bit complicated, i haven’t achieved it yet as i cant see the remote machine in the debug dialog
install remote debugger tool (on remote machine)
Download Visual Studio Tools - Install Free for Windows, Mac, Linux
(install on remote server if not already installed)
access server path
\[SERVER]\[ENVIRON]\Server\Assemblies\
Create, save, edit & enable BPM
Find the .cs file for your BPM
\[SERVER]\[ENVIRON]\Server\BPM\Sources[DIRECTIVE TYPE BO-DT][METHOD][LATEST VERSION]
eg \[SERVER]\d$\websites[ENVIRON]\Server\BPM\Sources\BO\Labour.GetList\8[BPM_Name].cs
Open METHOD.cs file in Visual Studio
Set Break Points in the .cs files
Attach to wpw3.process
Attach to process…
Dialog to connect to debugging service
find the server by name or public IP
attach the process
If multiple process, run cd C:\Windows\System32\inetsrv appcmd list wps on server to find the correct process ID
then C:\Windows\System32\inetsrv appcmd list wps
(select the one matching your current Epicor environment)
Leave BPM open in Visual Studio
Process BPM in Epicor
