I am executing ABL code through a data directive which is triggered when a new attachment is added to a material. The ABL code is writing the data to user defined fields in the JobMtl table, but the data is not available until I manually hit refresh on the standard toolbar, or reload the job. Is there a way to get the dataview to update after the ABL code has executed? I havent visited this in awhile and still at a standstill.
Thanks in advance,
Ted
Thanks in advance,
Ted
--- In vantage@yahoogroups.com, Ted Koch <tkoch77@...> wrote:
> I'm not sure which notification i should run my code with, I only want to send an email if an attachment has been added. I had tried edvAutoAttachJobMtlAttchOperationMaterial_EpiViewNotification, edvAutoAttachJobOperAttchOperation_EpiViewNotification, edvAutoAttachJobMtlAttchMaterial_EpiViewNotification. None of which did anything.
> From: Waffqle <waffqle@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, September 29, 2011 9:29 AM
> Subject: Re: [Vantage] DB not updating after data directive
> Try running your code on a notification instead of a method call. If that
> doesn't work, we probably need to see the rest of the code to figure out
> what's up.
> On Thu, Sep 29, 2011 at 9:25 AM, Ted Koch <tkoch77@...> wrote:
> > I had tried that before you posted and it didn't do anything different.
> > Sent: Thursday, September 29, 2011 9:16 AM
> > Oops! My fault, try this:
> > rsJobMtl.Notify(new EpiNotifyArgs(oTrans, rsJobMtl.Row, rsJobMtl.Column))
> > On Thu, Sep 29, 2011 at 9:11 AM, Ted Koch <tkoch77@...> wrote:
> > > It fails to compile this, Row is not a member of System.Data.DataView
> > > Sent: Thursday, September 29, 2011 9:00 AM
> > > Try this:
> > > rsJobMtl.Notify(new EpiNotifyArgs(oTrans, rsJobMtl.dataView.Row,
> > > rsJobMtl.Column));
> > > On Wed, Sep 28, 2011 at 1:05 PM, Ted Koch <tkoch77@...> wrote:
> > > > I have tried using this to notify the dataview. I am using the JobHead
> > > > table because I had started to use the character fields there to save
> > the
> > > > temp data.
> > > >Â Dim rsJobMtl As EpiDataView = CType(oTrans.EpiDataViews("JobHead"),
> > > > EpiDataView)
> > > >Â rsJobMtl.Notify(New EpiNotifyArgs(oTrans, rsJobMtl.dataView.Count,
> > > > rsJobMtl.Column))
> > > > Sent: Wednesday, September 28, 2011 11:44 AM
> > > > Are you notifying the dataview of the changes?
> > > > On Wed, Sep 28, 2011 at 10:44 AM, Ted Koch <tkoch77@...> wrote:
> > > > > I placed the code before the GetNewJobMtlAttch method and it is still
> > > > > producing the same results. The email code I am executing is actually
> > > in
> > > > a
> > > > > customization using sub oTrans_jobAdapter_BeforeAdapterMethod, I am
> > > only
> > > > > using a BPM data directive to get the Job Number, Asm, and MtlSeq and
> > > > > filename from the XFileAttch table and transferring it to a UD table
> > > > which
> > > > > works fine. It seems like it doesn't commit the new data in time for
> > > the
> > > > > dataview to see it. Just the previous attachment information is
> > pulled
> > > in
> > > > > each time.
> > > > > Sent: Wednesday, September 28, 2011 9:12 AM
> > > > > Run it before the method.
> > > > > On Wed, Sep 28, 2011 at 8:12 AM, tkoch77 <tkoch77@...> wrote:
> > > > > > Good Morning,
> > > > > > I have been trying to create a workflow to allow the sending of
> > > > > > information when an attachment is added to a job material. I have
> > all
> > > > the
> > > > > > code wrote for it, the only problem I am having is with the data
> > > > > directive
> > > > > > to store information from the XFileAttch table so it is available
> > to
> > > > me.
> > > > > I
> > > > > > am executing some ABL code to store XFileAttch values in
> > > Character01-04
> > > > > on a
> > > > > > UD table. It picks up the data I want, but not until I do a refresh
> > > on
> > > > > the
> > > > > > form. Is there a way around this refresh step so the data will be
> > > > > available
> > > > > > right after the ABL code has executed, or even code to force the
> > form
> > > > to
> > > > > > refresh? Currently when it is sendng the email, it is sending the
> > > data
> > > > > from
> > > > > > the last previous added attachment, not the current attachment.
> > Also,
> > > I
> > > > > am
> > > > > > executing the code to send the email after the GetNewJobMtlAttch
> > > method
> > > > > on
> > > > > > the JobEntry BO.
> > > > > > Thanks,
> > > > > > Ted
> > > > > *Waffqle Driggers*
> > > > > *High End Dev, System Design, Profit Drinking
> > > > > *:: 904.962.2887*
> > > > > *:: waffqle@...*
> > > > > *:: NO FAXES*
> > > > > [Non-text portions of this message have been removed]
> > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You
> > must
> > > > have
> > > > > already linked your email address to a yahoo id to enable access. )
> > > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > > and
> > > > > Crystal Reports and other 'goodies', please goto:
> > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > (2) To search through old msg's goto:
> > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > *Waffqle Driggers*
> > > > *:: 904.962.2887*
> > > > *:: waffqle@...*
> > > > *:: NO FAXES*
> > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must
> > > have
> > and
> > > *Waffqle Driggers*
> > > *:: 904.962.2887*
> > > *:: waffqle@...*
> > > *:: NO FAXES*
> > have
> > > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > *Waffqle Driggers*
> > *:: 904.962.2887*
> > *:: waffqle@...*
> > *:: NO FAXES*
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have
> >Â
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
> Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
