I happened to need this for something else so, since I was looking it up anyways here is the SQL that will give you a difference on the number of days when added to a calculated field.
ex.
DATEDIFF( day , LastCostAdj.Calculated_LastCostAdj , Constants.Today )
what they mean
DATEDIFF( Intervalday,month,year, hour, First date , second date )
Can I ask why that one is better? I kind of figured that the things that epicor gives you to pick from is a little better supported, and that constant is in the list. (Not always the case though)
I thought he was having issues with the constant from his post I thought he said he couldn’t use Today(), one isn’t necessarily better than the other I misunderstood his issues. I am fairly certain that the constant is just GetDate() either way though… I’ll look under the hood later.
