Database view in Kinetic form
Hi
Can anybody tell me if I can use a database view in Kinetic, as I need to call a view from sql server in Epicor database from a event in Kinetic form?
In someone could help me I would be grateful.
Thank you
I think what you should do is create an external BAQ that points to your database view. Then, the BAQ will be exposed to your data events to load into a new view in Kinetic like normal.
