Database shutdown w/ Veritas backup Vantage 6.1
Yes, you are correct. You cannot backup the running database with a normal
backup program. I run the Vantage online backup utility, then Veritas
backs up that file. I did notice that the DB directory was NOT excluded
from the Veritas backup job. I changed that and we will see what happens.
Just another joy of setting up a new server from scratch.
Sent: Thursday, July 07, 2005 8:12 AM
Subject: RE: [Vantage] Database shutdown w/ Veritas backup Vantage 6.1
Correct me if I am wrong, but I don't think you can back up the mfgsys
db.
You must run the backup online backup utility, and back up the resulting
file.
Regards,
Of Matt Sturm
Sent: Thursday, July 07, 2005 8:42 AM
Subject: [Vantage] Database shutdown w/ Veritas backup Vantage 6.1
Have an odd one for all of you.
Our setup: Dell Poweredge 2800, Dual 3.GHz proc., 3 Gb ram, Vantage is
on a 261gb raid partition - 250gb free, running Windows 2k3. Vantage
6.1.526, Progress 9.1d with latest service pack and patch.
For the last two days, whenever Veritas BackupExec 9.1 starts its
nightly backup job, The Vantage database shuts down. There are no
plug-ins installed into Veritas, so it shouldn't be sending any commands
to any other programs. I run the Vantage online backup before the tape
drive backup starts. The shutdown is recorded in the application log 40
minutes after the Vantage backup occurs, Just at the time the Veritas
backup starts.
Below are some of the error messages.
Message from PROGRESS database d:\epicor\mfgsys61\db\mfgsys (5199), APW
38:
bkioWrite:Unknown O/S error during write, errno 2, fd 736, len 4096,
offset 757574, file D:\epicor\mfgsys61\Db\mfgsys.d1. (9451).
38:
bkioWrite:Insufficient disk space during write, fd 736, len 4096, offset
757574, file D:\epicor\mfgsys61\Db\mfgsys.d1. (9450).
38:
bkwrite: write to disk failed errno 0. (3645).
Message from PROGRESS database d:\epicor\mfgsys61\db\mfgsys (5199), BIW
36:
Stopped. (2520)
SERVER :
Begin ABNORMAL shutdown code 2 (2249).
SERVER :
Multi-user session end. (334)
Sounds like some kind of drive issue but, when it occurs at the same
time as the nightly backup I am suspicious. As a test, I have moved the
timing of the nightly backup. This all started this week, work flawless
since the upgrade to 6.1. Nothing has been installed or changed on the
server. Maybe another security fix by Microsoft? ;)
Any Ideas would be appreciated. I am afraid this may be a round-robin
of finger pointing between Dell-Veritas-Epicor.
Matt Sturm
IT Administrator
Winona Lighting
Phone: 507-454-5113 ext. 361
Fax: 507-452-8528
Web: <http://www.winonalighting.com/ <http://www.winonalighting.com/> >
Http://www.winonalighting.com <Http://www.winonalighting.com>
E-mail: <mailto:msturm@...> msturm@...
Yahoo! Groups Links
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> "
on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
_____
Our setup: Dell Poweredge 2800, Dual 3.GHz proc., 3 Gb ram, Vantage is on a
261gb raid partition - 250gb free, running Windows 2k3. Vantage 6.1.526,
For the last two days, whenever Veritas BackupExec 9.1 starts its nightly
backup job, The Vantage database shuts down. There are no plug-ins
installed into Veritas, so it shouldn't be sending any commands to any other
programs. I run the Vantage online backup before the tape drive backup
starts. The shutdown is recorded in the application log 40 minutes after
the Vantage backup occurs, Just at the time the Veritas backup starts.
Message from PROGRESS database d:\epicor\mfgsys61\db\mfgsys (5199), APW 38:
bkioWrite:Unknown O/S error during write, errno 2, fd 736, len 4096, offset
Message from PROGRESS database d:\epicor\mfgsys61\db\mfgsys (5199), BIW 36:
Stopped. (2520)
Message from PROGRESS database d:\epicor\mfgsys61\db\mfgsys (5199), SERVER :
Sounds like some kind of drive issue but, when it occurs at the same time as
the nightly backup I am suspicious. As a test, I have moved the timing of
the nightly backup. This all started this week, work flawless since the
upgrade to 6.1. Nothing has been installed or changed on the server. Maybe
Any Ideas would be appreciated. I am afraid this may be a round-robin of
Matt Sturm
IT Administrator
Winona Lighting
Fax: 507-452-8528
Web: <http://www.winonalighting.com/> Http://www.winonalighting.com
db.
file.
Regards,
Of Matt Sturm
backup starts.
38:
38:
38:
36:
Stopped. (2520)
SERVER :
SERVER :
Matt Sturm
IT Administrator
Winona Lighting
Fax: 507-452-8528
Yahoo! Groups Links
Is your veritas backup job skipping the db directory? You can't backup a
running database.
Patrick Winter
Matt Sturm
Sent: Thursday, July 07, 2005 7:42 AM
To: 'vantage@yahoogroups.com'
Stopped. (2520)
Matt Sturm
IT Administrator
Winona Lighting
Fax: 507-452-8528
Yahoo! Groups Links
When I was changing my server over last year and was talking with
Support they made it very clear that your backup can not touch the DB
folder if it does your database can get corrupted. Not to sound
discouraging but that is what I was told and believe me it did happen
and I lost 3 months of data that we had to put back in. As for your
database shutting down on its own I have never heard of that, let alone
starting back up on its own. Good luck.
Of Matt Sturm
on a
6.1.526,
nightly
other
after
38:
offset
38:
38:
36:
Stopped. (2520)
SERVER :
SERVER :
time as
of
Maybe
of
Matt Sturm
IT Administrator
Winona Lighting
Fax: 507-452-8528
Yahoo! Groups Links
