Database Encyption
If somebody had a copy of your epicor database on a local pc and that pc was stolen, I believe someone could put the HDD in another machine and get access to your SQL tables. Assuming that’s correct, has anybody turned this on or using it? Does it work fine with Epicor and are there any performance considerations? I know Azure Sql has this on by default.
How to Enable Transparent Data Encryption — DatabaseJournal.com
