I am installing 10.2.600 in my test environment and the Data Discovery keeps telling me:
Installer has detected SSL/TLS vulnerability, Please review install logs for details.
Validation of Data Discovery Failed.
Fully Qualified SSL Domain Name is not a valid domain name as specified in the SSL Certificate for this server. Please enter a valid name that matches the SSL certificate installed in IIS
I went to IIS–>Server–>Server Certificates–>and am using the Domain name lsited there. I ahve also ran a command prompt, echo %COMPUTERNAME%.%USERDNSDOMAIN%, to bring up the FQDN and nothing is working.
Deployment of Data Discovery started.
Installation of Epicor Data Discovery Started.
ERROR: Failed to fetch token - (System.Net.Http.HttpRequestException): An error occurred while sending the request.
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Epicor.BI.DataDiscovery.Security.IceAuthScheme.d__5.MoveNext() in F:\TFSAgent_work\7\s\Epicor.BI.DataDiscovery.System\Security\IceAuthScheme.cs:line 214
Went to 10.2.600.4 and it had an SSL override, so I checked that. Everything went smooth until I got this error.
Deployment of Data Discovery Failed.
Errors:
Failed to deploy Epicor Data Discovery : Failed to back up file contents : Could not find a part of the path ‘C:\inetpub\wwwroot\Data Discovery’.
I do not have this folder location, it wasn’t installed. Is this something I create and it fills it??
