Data Directive UD Column not Selectable - Help Needed
I have added a UD Column in JobHead called Contract_c and had our data model regenerated. When I go to create a Data Directive against that field it is not selectable within the JobHead drop down even when the show custom fields checkbox is marked. Any Ideas on why this would be happening?
Does it show up when you go to BAQ Designer and select that table?
Yes it does.
I haven’t played with Data Directives in Kinetic, yet. But on 10.2.300 it would do this same thing. I would just have to workaround by manually setting it using an execute custom code widget and if you call it from the code it recognizes it and will set it. Or if I was using it in a conditional statement, I’d have to do the same thing in an Execute Custom Code widget. Kind of annoying. But not the end of the world.
