Data Directive Issue
Hello,
We have 2 companies in Epicor. I added a method directive to both companies to auto check a check box when a new order is created, both work. Then I created a standard data directive to send an email alert when the email address is updated in the approval field… The issue I’m having is it works for one company, but not the other. I double and triple checked and I’m doing everything the same exact way. Any thoughts?
Does the other company that is not working have the SMTP/email relay set up correctly?
Doesn’t look like it! I reached out to our IT to update it.
Thank you!
Please mark any answers as the answer so other people can learn from this. If you don’t know how to do that please let us know.
Yep, just waiting for confirmation that that did the trick.
