Not exactly the same but yes you can run BAQ’s in a directive… However since you are already in the server / back end seems like writing a quick LINQ query may save you some time
Thanks Jose – you know that you’re amazing and love to demonstrate to people with code examples…… J
This is my BAQ:
select
[JobHead].[JobNum] as [JobHead_JobNum],
[JobHead].[PartNum] as [JobHead_PartNum],
[JobHead].[ProdQty] as [JobHead_ProdQty],
[JobHead].[QtyCompleted] as [JobHead_QtyCompleted],
(JobHead.QtyCompleted - JobHead.ProdQty) as [Calculated_QtyVariance],
((case when QtyVariance = 0 then '' else (case when QtyVariance > 0 then 'Over' else 'Under' end) end)) as [Calculated_OverUnder],
((QtyVariance / JobHead.ProdQty) * 100) as [Calculated_PercentVariance]
from Erp.JobHead as JobHead
inner join Erp.Part as Part on
JobHead.Company = Part.Company
and JobHead.PartNum = Part.PartNum
and ( Part.MtlAnalysisCode = @Dept )
where (JobHead.ReqDueDate = @ProdDate and not JobHead.JobNum like '"K"')
Can you give me a starter for 10 on how to call this in a data directive BPM (standard), and I then plan to format as an HTML table and send via email. I’ve got code for converting from DataTable to HTML, so if the output of LINQ statement was DataTable that would be ideal…!
Not specific to your usage, but the names of the tables/fields have been changed to protect the innocent.
var Result = from D in Db.Device //this just gets results from the temp table parttrans which is the result of this BPM
join P in Db.SysPrinter
on new { D.Company, D.PrinterID } //link these
equals new { P.Company, P.PrinterID } // to these
where D.WorkStationID == Session.WorkstationID
select P.NetworkPath;
prntr = Result.FirstOrDefault();
I’ve got an interactive dashboard where I’ve built code to be able to Report Quantity and Receipt to Inventory in one button press. Does all the checks and balances on what’s permissible in terms of quantities etc.
This was an intention to add 4 buttons, 1 per department. Once they’ve finished producing the plan for the day, they press the button. I want to work out the plan adherence and send that in an email to production management team, and also customer services so they can see anything that was over/under produced and let customers know. I’ve got a basic email working using the DD bpm, triggered by writing an entry into UD05 from screen customisation. Just need to get that basic data from BAQ into an HTML table.
The data is presented in other places for meetings etc, this is just the early sending of info to relevant people.
