Thanks. I will check into adding the fields to the part table because they should be the same and updatable if there is a slight change.
Thank you again.
Sent: Tuesday, July 15, 2014 12:04 PM
Subject: [Vantage] RE: Dashboards
If you are expecting them to always be the same for a part, you should be able to add custom fields to the Part table
Sent: Tuesday, July 15, 2014 10:56 AM
Subject: [Vantage] Dashboards
I am trying to create a dashboard for the first time and I have one query that will be used (part number, sales order info). The other information I need is based on shipping the product (box weight, pallet weight, dimensions, etc.). Has anyone ever input information into Epicor, tied it to a part number and built a dashboard so the info can be retrieved every time the part number is entered?
Is it possible?
Millicent
This message is intended only for the addressee and may contain information that is company confidential or privileged. Any technical data in this message may be exported only in accordance with the U.S. International Traffic in Arms Regulations (22 CFR Parts 120-130) or the Export Administration Regulations (15 CFR Parts 730-774). Unauthorized use is strictly prohibited and may be unlawful. If you are not the intended recipient, or the person responsible for delivering to the intended recipient, you should not read, copy, disclose or otherwise use this message. If you have received this email in error, please delete it, and advise the sender immediately.
Thank you again.
Is it possible?
Millicent
