Dashboard URL/XSLT View
I wanted to add a new URL/XSLT View in dashboard. I created sample data in report tools. but the file format is .xml, how can I get .xslt format? Is there any tool that can convert .xml file to .xslt file? Thanks.
Is it possible that I can generate new URL/XSLT View from BAQs?
XSLT is an XML Transformation you can’t really convert XML to XSLT…
Thanks. I decided to use Generate ASP to build Web View.
Do you know do I need to change .asp or .xml code among the files which Epicor generate automatically?
I followed the steps in ICE Tools book, then I put all files in our server dictionary.
But when I opened .asp file, the search file can not work.
