Hi,
I have been making various dashboards for our company and have run into an issue with them:
Every time I add a tracker to a dashboard it doesn't work anymore. For example, when I add a date range to the tracker, once I enter a range (and I know data fits the criteria of the range) and hit the refresh button, instead of the dashboard only showing the data that fits within my range it does nothing. If I hit the refresh button once more the entire grid goes empty.
This happens for any type of prompt I add to the tracker. Whether I add the prompt using the tracker customization tool, or I add the prompt using the default tool... I have the same result.
I have spoken with Epicor technical support and sent them my dashboard definition with the BAQ's attached and it works fine on their server.
Has anyone else had an issue like this?
Good Morning,
What version of epicor are you using?
We have found issue with summary queries on dashboards not allowing application of filtered data via tracker view (version 905702). Additionally, in earlier versions, we found that trying to apply data filter to calculated field data wouldn't work reliably (9056xx). Other than that, we have our tracker filters work, runtime dashboards and dashboard assemblies.
I'm sorry to say we never got a fix and instead "design around" these disappointments.
Nancy
