Dashboard Tracker - not display result
Hi,
I create a tracker on dashboard. Project ID requires input and Project description can be pulled.
However, it does not display result! This does not happen before, can any one help?
Does entering the Project ID (then hitting refresh), select a row in the summary pane?
Hi Calvin,
I found the issue. It’s the underlying BAQ does not join properly.
